It is currently Wed Jun 25, 2025 10:16 pm
 Post subject: Replacement Panels
PostPosted: Sun Dec 19, 2010 5:00 pm
Hi All,
Just wanted to get an idea of which replacement panels are easier to work with.
I thing I may have to replace the A panels on my 61, and maybe a few others as well.
I'm going to have a good look over the old girl at Christmas and figure out what I need.
So far it's probably A panels and maybe the door skins. Looks like the doors may have opened a bit too far at some stage.
Ian
PostPosted: Sun Dec 19, 2010 6:12 pm
reckon the easiest panel to replace would be:
1. Rear beaver panel
2. Battery box
3. A-panels
from here it gets harder
(apart from bolt on panels
Ive taken these pales off and they were not too difficult, so putting them on wouldnt be too hard.
I have replaced a-panels as well (outer) it wasnt too difficult, just trying to line the bolt holes up ans the curve and trying to the seams together a bbit fiddly, but worth having ago at.
Thats about af far as my replacements have gone soo far
Brenton
PostPosted: Sun Dec 19, 2010 6:32 pm
just replaced a front lower guard....
pretty simple and i was a complete beginner in welding ..
Try and practice some welding on the old panel before you jump
into replacing it cause you'll blow holes everywhere if you don't....
I have a boot floor to do but thats looking to go in the two hard basket..
reckon ill just do patching jobs in the boot.......
Cheers Hoba
PostPosted: Sun Dec 19, 2010 6:50 pm
If you want an as straight forward job as possible it is probably worth buying genuine panels instead of cheapy's. I bought all after market panels for my rebuild and they are not perfect so a bit of extra time and stuffing around is needed when fitting them.
The other thing I noticed with the cheaper panels is the corners of the forming are not as sharp as the original car so I will need to use some filler to get the edges of some panels to a radius they should be.
Mini's I grew up with
Slot car couch
Users browsing this forum: No registered users and 120 guests
