It is currently Wed Aug 06, 2025 2:37 pm
PostPosted: Wed Dec 22, 2010 8:12 pm
i just got a diahatsu charade alt for 15$ how would u guys wire it up?
1974 clubby with round nose conversion
1100 motor
extractors
twin 1 1/4" su's
lumpy cam (dunno what 1)
2 1/2" exaust
http://www.ausmini.com/forums/viewtopic ... sc&start=0
PostPosted: Wed Dec 22, 2010 10:06 pm
Depends which model, this site covers a few of them
http://westfield-world.com/daihatsu_alternator.html
2008 Prado GXL
PostPosted: Wed Dec 22, 2010 10:38 pm
So you confirmed that your old alternator is U/S didnt you?
PostPosted: Thu Dec 23, 2010 12:30 pm
Have you taken the old one out yet? If not, I have a few suggestions.
1. Get the battery charged up with a charger.
2. Hook it up, switch the car's accessories on. The battery shouldn't spark when you attach it - if it does, the diodes in the alternator are worn or wearing out. Both the charging and oil lights should be on before you start the engine. If the charging light is not on, check the charging light plug on the alternator, and the charging bulb on the dash. If either of these don't work, the alternator will not charge.
3. Start the car, and check that the charging light turns off (as well as the oil light). If it doesn't, it will most likely be the alternator, the alternator plugs, or the engine grounding strap.
PostPosted: Thu Dec 23, 2010 8:29 pm
the old one is out and the new one is in ... the battery light was on all the time
1100 motor
extractors
twin 1 1/4" su's
2 1/2" exaust
PostPosted: Thu Dec 23, 2010 10:03 pm
So all fixed then?
