It is currently Sun Jul 27, 2025 8:48 pm
PostPosted: Mon Dec 27, 2010 12:30 pm
right i got it working! thank god. faulty edis & sensor did not seem to be sitting right.
one thing is odd & maybe i have wired the plug/sensor wrong?
it is showing load & revs from the bottom instead of the top.
what i see on youtube it starts from the top & works it's way down?
so instead of descending as normal it's Ascending!
maybe the wires are reversed? on the sensor? when i commit a map nothing seems to really change
and it's idling ok around 550 to 600 feels to low and kinda bit lumpy & i have a 266 cam.. i think that is my twin su's needing a tune up as it does it with the dizzy also.
but at least it's working now im happy i got it to work one step closer!
so what do you think ??
PostPosted: Mon Dec 27, 2010 12:41 pm
NG, I'm jut connecting up my MJ too using one of Ben's trigger wheels and at TDC the sensor on mine is pointing at the gap between tooth 8 and 9 too. Did you have to ajust the sensor bracket or is that OK?
PostPosted: Mon Dec 27, 2010 1:12 pm
i have no idea i have been winging it to be honest.
try it and see if it starts and runs if not then you know it's not right.
PostPosted: Mon Dec 27, 2010 5:00 pm
Aah, I should have re-checked before posting. The bracket from Ben was already slotted so easy to re-align so that now the sensor points at the 9th tooth.
PostPosted: Mon Dec 27, 2010 9:40 pm
Like I said earlier, there's fine tune adjustment in the software to allow for any small misalignment.
tim
PostPosted: Tue Dec 28, 2010 4:41 am
Cool thanks tim.
Any idea why the software is ascending instead of descending ?
Seems like a odd thing
PostPosted: Tue Dec 28, 2010 6:48 am
i thought you went supercharger
PostPosted: Tue Dec 28, 2010 8:24 pm
i still am. i just need to sort out the ignition first :)
PostPosted: Wed Dec 29, 2010 7:18 pm
got it working!!! wooo it's bloody smooth!!!
turns out my 2 Edis untis from ebay were both faulty hopefully badluck & not something wrong with my harness.
hopefully this one form the wreckers this time is fine.
it's not so lumpy like on a dizzy hard to explain but it's really solid now.
very impressed. blower next :D
