It is currently Wed Jul 23, 2025 11:20 pm
 Post subject: Overheating and fans
PostPosted: Thu Dec 30, 2010 6:40 pm
Been chasing an overheating issue on a standard Mini 1100, and find that it has a different yellow plastic fan compared to others I have. The blades have about 30% less surface area. They are notably narrower on the outer end.
All fans are Mowog. The one with the narrower blades is 12G1305, and other I have is a 12G2129.
Both fans have the same number of blades and pitch.
Any thoughts on this?
PostPosted: Thu Dec 30, 2010 6:45 pm
The wide ones (which superseded the narrow ones) move more air but they bend more..
Even the old metal 16 blader moved plenty of air.
Are you sure it's not a radiator problem?
PostPosted: Thu Dec 30, 2010 7:23 pm
That's basically the first things to check
Does your radiator need to be cleaned and re-cored ?
Does your radiator cap ( 13lb ) actually fit properly ?
What temperature thermostat are you using ( 82deg is better ) ?
PostPosted: Thu Dec 30, 2010 7:25 pm
I have the radiator out to double check it. That was when I noticed the different fan. I doubt the fan will make much differance, however I will still swap it over.
Users browsing this forum: No registered users and 127 guests
