It is currently Wed Jul 23, 2025 1:39 am
 Post subject: fitting new cwp
PostPosted: Mon Jan 03, 2011 10:21 am
I have been advised that if I wish to put a 3.1 cwp into my gearbox i will need to grind some bearing carrier ?
Any advise or susgestions ?
Has anyone done this before ?
cheers Jon
PostPosted: Mon Jan 03, 2011 10:37 am
The bigger pinion can foul inside the 3rd motion shaft bearing carrier. If it's a rodchange box it should/might be OK, but all remote change boxes need the carrier's inside diameter increased to 57mm approx.
It's a 5 min job in a lathe. :wink:
If no lathe you can grind it out by hand, it's only clearance.
PostPosted: Mon Jan 03, 2011 11:07 am
cool thank you the great wise doc.
is it g/box off engine job or can i do it carefully through the diff opening ?
PostPosted: Mon Jan 03, 2011 11:12 am
Mods rock!
If it's needed, you can get it off through the end cover.
Users browsing this forum: Bing [Bot] and 92 guests
