It is currently Tue Jun 24, 2025 6:35 pm
PostPosted: Fri Jan 07, 2011 10:18 am
I've just been for a quick fang in my mini for the first time since April last year!
I took it out to Syd's (Tspeed Jem) place to pop out the engine and install a central oil pickup so that I could have more fun at the roundabouts. No problem. We decided to install a new layshaft and bearings while we were at it. Once the engine was back in the car we tried to put the car into gear and discovered that we had nothing but reverse (not as useful as you'd think).
One of the other club members suggested that we may have used a slightly long bolt when we reinstalled the bearing retainer. So out came the engine for the second time. Popped of one of the side covers on the gearbox and sure enough that was exactly what the problem was. We put it all back together and back in the car. This time we had all the gears but when we started it up, there was an obvious leak at the manifold and the car wouldn't run. One of the stud holes was stripped and wouldn't hold tight. So off came the head and we ordered a helicoil kit from fleabay. When that came, we helicoiled the hold and one of the other ones which was looking a little dodgy.
It was then time to clean up the block face and put the head back on. That's when Syd noticed a sizable chuck missing from the edge of piston 4. Bugger, time for a long overdue engine rebuild. We pulled out the engine, stripped it and took it down to Berco for machining. Luckily the bore was undamaged to we just had it bored out a further 10 thou to 30 thou. I bought a new set of pistons and bearings and had GR grind an RE83 cam. We then reassembled everything, dialled in the cam and put it back in the car. I went for some dished pistons as the old flat-top Mahles had the compression up at over 13:1. Probably the cause of the detonation which killed the old piston. The compression should now be more like 10.5:1.
Next step was to run in the cam. No problem, fired it up and ran it at 3,000 rpm for about 20 minutes. Syd then put his foot on the clutch to move the car out of the garage and the engine promptly stopped. Bugger again. To cut a long story short, we had managed to install half the thrust washers in backwards. I ordered a new set of thrust washers and we put them in and put everything back together and back in the car. At the same time, I had read a post on here about putting the piston rings in the right way up. We pulled each of the pistons back out and discovered that I had managed to put 7 or the 8 rings in upside down.
We took the car for a quick test run and it wasn't too bad at low revs but the spark seemed to break down when it was given a bit. That's when Syd noticed that the coil was wired up backwards. Once this was rectified, the car started to run beautifully.
I drove it back from Syd's yesterday and went for a running-in fang this morning. The RE83 seems to pull very strongly and I'm very happy with it so far. I'll try to get out for a decent run in the next couple of days.
I've made a lot of mistakes in this whole process but learnt a hell of a lot as well.
Heaps of thanks especially to Syd (Tspeed Jem) for his time and garage and also to Santino and Scott.
Number 4 piston. You can see the marks from the broken bits of piston. It must have exited the cylinder fairly quickly as there aren't too many marks.
Where you shouldn't stick a long bolt
PostPosted: Fri Jan 07, 2011 10:40 am
Glad you've finally got to enjoy it.
Nice post about some of the traps for the first time builders too.
PostPosted: Fri Jan 07, 2011 11:31 am
sorry, but I couldn't stop myself laughing - the comedy of errors! :lol: :lol:
PostPosted: Fri Jan 07, 2011 11:46 am
I don't mind so much now that I'm looking back at it but I was beginning to lose my sense of humour when I realised that I needed to pull the engine out for the fourth time
:D :D
PostPosted: Fri Jan 07, 2011 1:13 pm
How frustrating. But you did the right thing. Rather than smash the car with hammer, set fire to it or sell it, you just shut the garage door and ignored it for a couple of weeks.
Brett.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Jan 07, 2011 4:02 pm
Experience is just an easy way of saying...I've made a lot mistakes.:x
Well done and 10 out of 10 for persistence. :D
PostPosted: Fri Jan 07, 2011 10:50 pm
We'll just call you "wingnut motors" :lol: Well done in getting it sorted and back on the road. Time to enjoy it now.
PeterN
3x Leylands
1x 850
Mildura,
Victoria.
PostPosted: Fri Jan 07, 2011 11:04 pm
Out of interest, how many times did you throw spanners about or have a tantrum?
I wouldve quit for at least a year after the second time the engine had to come out.
Simplify and add lightness
PostPosted: Fri Jan 07, 2011 11:06 pm
Totally agree! But only if you learn by it.
Congratilations on your perserverence and enjoy it now. 8)
PostPosted: Sat Jan 08, 2011 7:38 am
This is where it is good to have other people around at the time. I tend to act more sensibly when there are witnesses. :)
And I love have a mini on the road so it had to be fixed... eventually.
Watching the perserverance of some of the Nb guys is humbling. Santino had got his car ready for the Tasman Revival, paid his entry fees and accomodation and then dragged his car up to Sydney from Canberra. During practice, the car is down on power so he takes the head off and finds out that the block is badly cracked. Instead of cracking the sh!ts, he just packed it all up and came home. The next day, the engine is out and the whole thing is stripped down to a bare block to assess what can be done to fix it. That takes stoicism.
Users browsing this forum: Bing [Bot] and 79 guests
