It is currently Mon Jul 28, 2025 12:50 am
PostPosted: Wed Apr 06, 2005 10:08 pm
Hi guys and girls,
thing: By Pass tube from block to head
top Hex threaded Tube
www.angelfire.com/mech/ducho
first two pictures
i couldnt get it out with a spanner
i tried pincing pliers
and it collapsed it
any ideas on how to remove it?
i know if all else fails im gonna have to angle grind away the collapsed
and plug it
which i'd like to leave to the last resort
Thanks in advance
Inconspicuously Conspicuous
PostPosted: Wed Apr 06, 2005 10:12 pm
yea......nasty one....
didn't you have the head off recently? THAT would have been the best time to do it. It might be seized....and need drilling out..... :cry: sorry Duc.....
PostPosted: Wed Apr 06, 2005 10:15 pm
yeh it completely slipped my mind when the head was off
how would i go about removing it by drilling?
ive heard of a method
you cut it, and slowly tap it out
im really getting anxious :cry:
PostPosted: Wed Apr 06, 2005 10:19 pm
oh Duc.....I know EXACTLY how you feel...... :cry:
Mate, all I know is that when the head is off, if you can't screw it out, drill it out and retap it. Kev might know a way to do it with the head on.....
If you have to remove the head, it's not a HUGE job.....
You have reminded me to do mine. It is slightly corroded, but since the head is off, I should do it. How much was the insert?
PostPosted: Wed Apr 06, 2005 10:21 pm
$10 from heritage MG
ill give you mine if i dont get to use it
:cry:
PostPosted: Wed Apr 06, 2005 10:26 pm
I think you have two options,
1try to get a ring spanner over the nut and turn it an 1/8th at a time, It's tight in there. You may need to pull the radiator to get enough room. or get a cheap spanner and cut it down to get more room.
2 lop off the rest of the hose bit and get a socket onto it. and do the same. YOu'll need a short rachet for it to work. There tight, as there in water ALL the time. so there corroded in! joy! Patience will be the key...
Aaron
Duc,
I make brass ones that NEVER rust out.. :lol:
Head has to come off. If the adapter is stuffed I drill it all away then clean the thread out. Never stuffed a head up yet. :wink:
Bring it up and I'll do it while you wait, but I would need to make some adaptors first. 8)
PostPosted: Wed Apr 06, 2005 10:36 pm
thanks guys for the hints
i feel much better
hey i didnt even say any words starting with F
aaron, i couldnt get a ring spanner in there, nor a normal one
the horns of the spanner dig into the head
ill give the socket a go tonight
Doc, ill cut away the tube and will try to chip/drill/tap away the remains
the little tube is aluminium, i thought they never rust
i guess if its bathing in coolant the protective Aluminium Oxide could dissolve
thanks mate
PostPosted: Wed Apr 06, 2005 10:55 pm
Yer take the head off and do it on a bench...Fare bloody easier....you will be banging your head against a wall otherwise..then your head will look likemine...and you don't want that :?
PostPosted: Thu Apr 07, 2005 12:02 am
socket didnt work
ring spanner didnt work
rad was out from the start
water pump now out
hermans sitting there with his guts all over the garage
will speak to a friend before taking the next step
looks like head will come off
cheers boys
duc
ps. who'd believe it, i didnt even cuss :wink:
pps. lets see if i can get him on the road by next next weekend in time for the terrigal cruise
PostPosted: Thu Apr 07, 2005 4:30 am
No Jim yours is more like against a linisher.
68matic - take the head off. Once youve done it a few times and with the radiator already disconnected it only takes like 2 hours each way (unless your extractors missalign, or radiator leaks). The current position of the bypass is the wrong place to do any kind of work - you've got no access, no vision, no angle to apply force and youre bound to strip it even further or fk the thread.
PostPosted: Thu Apr 07, 2005 8:36 am
thanks mike
dont wanna fk anything up
PostPosted: Thu Apr 07, 2005 12:14 pm
does anyone else tap and block off the bypass altogether? the last couple of motors I did we blocked it off, which makes life much easier. Put a plug in the head, and tap & plug the outlet on the water pump.... no more leaking bypass hoses, no more lining the bastards up when you put the head on etc. etc.
the bypass hose is there to let a little bit of hot water stay inside the engine - it bypasses the radiator.... basically keeping the motor hotter, the poms needed it, we don't ;)
anyone else do the same?
PostPosted: Thu Apr 07, 2005 6:32 pm
skssgn
i really dont know if thats the purpose of it
as Doc said once
god put it there for a reason
so blocking it off might be beneficial for now
but i'd prefer to keep it like it is
PostPosted: Thu Apr 07, 2005 6:37 pm
I thought thats what I said :lol: Linisher :?:
