It is currently Sat Jul 19, 2025 3:50 am
 Post subject: needle selction
PostPosted: Fri Jan 07, 2011 11:24 pm
hey guys just looking for a starting point or some advice on choosing a needle for my current set up.
i have a HS4 carb with the standard needle that comes with the rebuild kit.
since then i have done the following changes:
rc40 twin can
maniflow 3-1 extractors
minispares water heated inlet manifold
worked 202 head
1.5 rockers
ramflow air filter
stock cam, pistons and crank for now :lol:
any advice would be greatly appreciated.
cheers, Matt
"if its got tits or tires it'll cost yah"
PostPosted: Sat Jan 08, 2011 6:25 am
Mods rock!
How many CC's your engine?
PostPosted: Sat Jan 08, 2011 7:21 am
haha i knew i forgot something, 998 on standard bore
PostPosted: Sat Jan 08, 2011 6:53 pm
Try a no 7 needle to start with. :wink:
PostPosted: Sun Jan 09, 2011 6:02 pm
awesome will do, whilst out needle shopping what would you recommend with the following mods? as i plan to do the rest of the engine in the next 6 weeks.
mild cam to suit (any suggestions?), 20tho flat tops, lightened flywheel and crank.
all fully balanced?
cheers, Matt
PostPosted: Sun Jan 09, 2011 6:18 pm
all fully balanced?
cheers, Matt
I would still stay with the no 7 needle initially.
Then either borrow a portable wideband A/F meter and go for a drive under load, or preferably put it on a dyno, to get the mixture right.
As for cams, it all depends what engine characteristics you want. The one Mick just put in his 997/8 Cooper (RE83) would be my pick for a torquey road cam.
PostPosted: Sun Jan 09, 2011 6:36 pm
yeah, i live 5 mins away from mick and he has been an invaluable resource :lol: he also recommended the re83, so i think that will be the go.
i will get it on a dyno after the engine has been rebuilt to get it tuned properly.
PostPosted: Sun Jan 09, 2011 7:07 pm
With my new motor, I've cut the commute down to 4 minutes.
PostPosted: Sun Jan 09, 2011 7:58 pm
haha yeah i bet, you have to take me for a ride in it later on in the week, it sounded mental the other day
PostPosted: Tue Jan 11, 2011 12:07 pm
Rover Cooper
I would like to follow you two around for a while, :( just listening to that rock and roll spilling out from the back, :roll: :roll: let me know when you are testing it again and I will tag along....LOL... :wink: :wink: :wink: :wink:
PostPosted: Tue Jan 11, 2011 1:05 pm
I'll be round micks place tomorrow for some more testing :lol:
