GR wrote:
Hi Phat Kat
The cam that you have shown there is one of deans first cam blanks they were made from 4140 and after they were ground and treated the lines in the cam that you can see was the grain structure in the 4140 all cams are finished ground not cut by any other means he made very few out of this material.
the steel he uses to day is a spring steel and the hardness of these cams when finished ground is far better than any cam on the market to day, his cams are all up around the 50 to 56 rockwell c the ones i have been getting from over seas on the base circle and up on the flanks get down to low 20s which is rubbish thats why i heat treat them my self to try and get them up to around 60 RC to get some life out of them in the race engines,the one that MINImal has shown is the latest material and you can see the difference in the material.
Graham Russell
Oh no Graham, that is not a Tighe cam in my photo... Not at all. If you want to know who's that was PM me.
4140 is a pretty popular material for camshafts (or at least was). I hear what you are saying loud and clear, and it makes sense and certainly looks that way... however, you can actually feel those lines when you run your finger nail over them, I wouldn't imagine that would normally be the case after it had been ground... which is what led me to believe that it may have been roughed out by some other means (other than grinding).
Thanks for the rest of the info too.
Alex
<edit> Actually Graham, having a closer look at the rest of the camshaft (not just the lobes) what you are saying makes perfect sense..
If you look at the lobe for the fuel pump in this photo...
...you can see that the lines are not parrallel as you'd expect if it were "cut".
