It is currently Sat Jul 19, 2025 3:49 am
PostPosted: Wed Sep 15, 2010 3:10 pm
Holy moly that first post is 10752 characters long....!
PostPosted: Wed Sep 15, 2010 3:43 pm
This space for rent
Most of them commas!!!
PostPosted: Thu Sep 16, 2010 6:18 am
Hey this is all good stuff...
Now on shrouding and valve sizes, I'm planning the worst of those combos - a 940 style head on a small bore block!
Obviously the exhaust valve will be shrouded by the block so the relief's cut in the block do more than just allow the exhaust valve to not hit the block, they let the exhaust by as well?
Low lift flow is something I'm always chasing - tell us what mods enhance them Matty! 30 degree valve backcut? 3 angle seats? super-thin seats?
Jacob
PostPosted: Thu Sep 16, 2010 7:51 am
After that I feel a little exhausted, so I'm going to get a little intake and idle down.
PostPosted: Fri Sep 17, 2010 7:13 pm
heee hee... that was witty,,, very nice,,, well done :-)
i`ll throw some more on this subject up next week, i`m just letting my typing fingers heal a bit first :-)
PostPosted: Fri Sep 17, 2010 7:27 pm
Jacob
I had a 12G940 head (1100S valves, some porting) on a 1220 smallblock back in `68. With a 544 cam and twin HS4s it was good for low 16s down the Castlereagh dragstrip. Pretty quick time with road tyres ((Olympic GT radials?) on back then.
For the cutout shape I put an 850 gasket on the block, and traced the outline on the exhaust side. Depth was .100".
 Post subject: 940 on a small bore
PostPosted: Sun Oct 03, 2010 6:13 am
Hey Jacob,
Another option on the large bore head on a small bore, measure the amount of valve protruding below the head face a max lift and sink the valve seat by this amount, no pockets needed in the block, ask Keith....
a very jet lagged Kevin
Oh and Matty, haven't read most of the rest but methinks 'maximise low lift flow and port speed...' :D
 Post subject: Re: 940 on a small bore
PostPosted: Sun Oct 03, 2010 8:48 am
rathcoole wrote:
Hey Jacob,
Yeah that works, but not if you have a hi lift cam and/or rockers... :wink:
PostPosted: Sun Oct 03, 2010 9:09 am
Kev you're back!! :P
Beginning to wonder if you got lost over there ;)
Ok Kev & Kev (just realised, I know rathcoole is Kev... but u too Drmini..yeah?) Yeah I thought I might be okay with the "sink the seats" trick, but I'm using 1.3:1 rollers & a cam with 0.268" lift - when you measure it all up, the exhaust valve *just* makes it past the face of the head.
So some shallow cut-outs should be fine, I need to remeasure everything for an exact figure.
Jacob
PostPosted: Sat Oct 09, 2010 12:33 am
ha ha,,, Kev & Kev,,,, :-) Kev you`re back,,, how was the "Home-land" ????
eye to be sure to be sure :-) are you sick of Guiness yet????
what happened to you tonight??? was waiting up for you,,, still am :-)
& yes Jacob,,, leave about 40 or 50 thou clearance for those "missed gear" over revs,,, you know,,, when things tend to grow a tad longer :-)
 Post subject: Area calculations
PostPosted: Wed Jan 12, 2011 9:02 pm
Great thread Miniman,
Makes sense what you are saying, as much of it as I can take in atm anyway :wink:
1 Question, would it be better to compare the porting dia to the valve shroud diametre using cross sectional area calculations?
Valve shroud cross sectional area calculation
7mm valve stem cross sectional area =
3.14 x (rxr)
3.14 x (3.3x3.5)
3.14 x 12.25
38.47mm sqr
31mm valve outside - 1.5 seat radius = 28dia
3.14 x (rxr)
3.14 x (14x14)
3.14 x 196
615.44mm sqr
615.44mm sqr - 38.47mm sqr = 576.97mm sqr (cross sectional area through valve shroud area)
Inlet port cross sectional area calculation
Ported area of 26mm dia =
3.14 x (rxr)
3.14 x (13x13)
3.14 x 169
530mm sqr (cross sectional area of port)
Slightly different results but still your methodology stands up.
I actually have a 12G202 head that has some mild porting similar to what you have described. Might just give it a bit of a clean up around the chambers and use it for a nice road performance head.
Mini's I grew up with
Slot car couch
