It is currently Fri Jul 18, 2025 11:48 am
PostPosted: Thu Jan 13, 2011 8:36 pm
http://www.r1manx.com/www.r1manx.com/Components.html
Gets around the rear engine issue........
PostPosted: Thu Jan 13, 2011 8:38 pm
edited... sorry double posted
PostPosted: Thu Jan 13, 2011 8:39 pm
Or thishttp://www.pro-motive.co.uk/R1KitInfo.html
PostPosted: Thu Jan 13, 2011 9:08 pm
The front mount, FWD R1 conversion looks good but the big issue in Australia is reverse. These kits have electric reverse not mechanical like a car should have. Depending on the engineer you get to approve the kit and if your lucky the transport department may let it pass with the electric reverse but they may not and then you have a very expensive track car :? .
If you want to get it road registered you will need to find out 100% what your allowed to use and then make it work or give up.
PostPosted: Fri Jan 14, 2011 4:58 pm
i thought any reverse was good enough........
it just had to have one!???!
I liked the look of this due to there not being hassle with having the engine in the rear, so both from the transport/engineer side it was a winner and practically its good too.... maybe just a little bit of extra driver effort required when using the right foot with excessive force! :lol:
PostPosted: Fri Jan 14, 2011 11:09 pm
The problem with elc reverse is it's generally a starter motor driving a cog on the diff. A starter motor only has one speed, with that set up you would need to gear it to be very slow (walking/strolling pace). Or you could set it up to be a variable speed controller on the reverse starter, then you have to figure out how to control that speed. Same with the single speed option, how do you turn it on and off?
A mechanical reverse would be used similar to any normal car, controllable by the clutch and accelerator.
PostPosted: Fri Jan 14, 2011 11:59 pm
The pro-motive kit now comes with a mechanical reverse gearbox, with reverse selectable via a cable.
That'd meet aussie requirements, surely?
 Post subject: Mechanical reverse
PostPosted: Sun Jan 23, 2011 9:44 pm
This thread is quite intereting!
Can anyone shed some light or confirm PeeTee's comments on the Pro-motive Kit?
PostPosted: Sun Jan 23, 2011 9:47 pm
if you look at the link...... 2nd thing dowwn in a mechanical reverse
PostPosted: Mon Jan 24, 2011 7:50 am
Yeah I noticed that, the question is.... would this be accepted in NSW as an approrpriate reverse mechanism (which would then make the R1 conversion worthwile)?
I am hoping someone might be able to confirm this?
PostPosted: Mon Jan 24, 2011 11:40 am
if you do choose to do this type of conversion, i suggest you modify the sump & relief-valve tulip & fit anti oil surge baffle plate
& add extra oil
Here`s one i prepared earlier--> this is my own R1 engine fitted into a mini front subframe coupled to a space-frame--->
http://www.youtube.com/watch?v=wmE1kYeGPps
i was lazy & didn`t do the sump mods that are really needed when fitting bike engines into car chassis, i just added extra oil but it`s just not enough, you really do "NEED" the anti oil surge baffle mods done
http://www.youtube.com/watch?v=To8-usWZLrQ
the reverse gear is easy enough, simply contact --->
Powertech Engineering
24 Ivatt Way Business Park
Westwood
Peterborough
PE3 7PG
0044 (0) 1733 331919
0044 (0) 1733 333666 Fax
[email protected]
 Post subject: R1 conversion
PostPosted: Mon Jan 24, 2011 2:36 pm
Saw your clips... Quite impressive!
You mentioned attaching the R1 to a mini subframe, was this then connected to the rear or was it at the front (hard to tell by the clip)?
Also, the contact details for the reverse information, is that in Tasmania as I am interested in what the NSW engineers think about it?
PostPosted: Mon Jan 24, 2011 9:57 pm
That definitely aint a Tasmania address mate... they're different but not that different :)
They're in the UK.
Answer the Question....
BUT always Question the Answer
PostPosted: Tue Jun 14, 2011 5:48 pm
Think i am going for it..........
Have a shell and a voice in my head telling me too...... :shock:
PostPosted: Tue Jun 14, 2011 10:00 pm
Yes do it :!:
But have you talked to some engineers and your local RTA yet? otherwise you might end up with a nice track only car....
