It is currently Wed Jul 30, 2025 12:13 am
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Sun Jan 16, 2011 8:42 pm
what sort of fuel pump do you have?
I have an electric fedtro facet copy, and it seems to be playing up or showing signs of a blocked fuel filter. These electric ones usually have a small filter before the pump.
My car would cut out, splutter and come to a stop as the fuel pump couldn't keep up with the required fuel. If I left the car with ignition on, to keep the fuel pump ticking over, it would gradually fill the main fuel filter in the engine bay, and off we go again for another few k's, then rinse and repeat all the way home for 60 kilometers.
But if you have a mechanical pump you can disregard all of the above!
Tim.
tim
PostPosted: Sun Jan 16, 2011 9:49 pm
fuel pump is mechanical.... i can hear on start up and after i release the fuel cut out switch. after youtubing... i'm thinking start up fuel problems are blocked fuel filter (1000km old) and the running of the lil beast must be a timing problem..... none of this is confirmed but after some greasy hands tomorrow i'll let you know how this novice is going.....
thanks for all your suport,
fingers crossed lil miko will ride again soon
 Post subject: gremlin update with pics
PostPosted: Tue Feb 01, 2011 3:55 pm
so finally after working a million days straight, i got some spare time to have a little hunt around under the bonnet.
i think a may have found the start of my problems....
thanks all soo much for your advice.
so it appears the tip of the rotor is burnt.
(sorry for iphone pics, but all i had on hand)
any suggestions? some serious arcing? condensor shod?
or strip and rebuild the lot?
love any feed back
cheers miko
PostPosted: Tue Feb 01, 2011 4:23 pm
my guess is that the condensor is stuffed & points need replacing too
just a guess tho cause i`m not there eye-balling things myself, with my glasses on & a good light & my testing gear :-)
PostPosted: Thu Feb 03, 2011 3:56 pm
thanks for the response miniman.
most the guys on here said to inspect ignition, timing, etc...
and right they were.
looks like a mild dizzy rebuild coming up.
thanks again all,
hope to be back on the road soon
PostPosted: Thu Feb 03, 2011 6:23 pm
I'd put a Britparts ETC5835K electronic kit in it, then toss out the old points, rotor and condenser.
No more points problems... :D
And not much dearer then replacing all those.
