It is currently Fri Aug 08, 2025 5:12 pm
 Post subject: Tail Light Globes
PostPosted: Thu Jan 27, 2011 1:26 pm
I know Id have the info at home, but was gunna pick some new globes up on my way home this arv.
A few years back I fitted LED stop/tail and ind lamps. I think they might be to directional and dont light the plastic lens up as well as a standard filament lamp.
So what is the recommended wattage of stop/tail and ind lamps?
These are they ones currently fitted:
PostPosted: Thu Jan 27, 2011 2:11 pm
Yeah I reckon they're too directional as well, you'd need some sort of diffuser on a mini tailight.
Are you after the original spec lamp ratings? Brake is dual filament 21W+5W & the indicator is just a single 21W.
Jacob
PostPosted: Thu Jan 27, 2011 2:22 pm
Brilliant. Yeah just after the stock ratings.
PostPosted: Fri Jan 28, 2011 11:21 pm
Anyone want a free set of LED indicators and Stop/Tail lamps?
The standard filament globes are much better!!!!!
PostPosted: Sat Jan 29, 2011 6:40 am
Mods rock!
I have seen a lot of the LED 'bulbs' available for retro fit as a replacement for the stock filiment types but they all say (to the effect) that they are not suitable for road use. Maybe this is why?
PostPosted: Sat Jan 29, 2011 7:02 am
I have something similar to these to install
David L
PostPosted: Sat Jan 29, 2011 9:13 am
They might b kinda ok with the LEDS around the outside of them. But I found they just weren't as bright as a filament globe.
Users browsing this forum: Bill B, Bing [Bot] and 90 guests
