It is currently Sat Aug 09, 2025 11:43 am
PostPosted: Fri Jan 28, 2011 9:47 pm
would explain my highway fuel consumption lol.
look forward to the tune tomorrow.
but with the thinner oil & the play it's running alot better.
PostPosted: Fri Jan 28, 2011 9:53 pm
This space for rent
Nah, the damper oil only plays a part when you stick your boot into it. It's the SU equivalent of an accelerator pump on lesser carbies :lol: At constant throttle position, the needle profile dictates the fuel flow.
PostPosted: Fri Jan 28, 2011 9:59 pm
yeh i played with the mixture a bit & tried to lean it off.
but honestly i'm not a engine tuner so would rather pay to have it tuned & driving right.
but im surprised how much the oil made a difference.
idle as well the revs slowly died & i think the pot was having trouble moving up & down.
PostPosted: Fri Jan 28, 2011 10:06 pm
This space for rent
Yeah the dashpot oil changes the response of the engine when you expect a response -- i.e., when you put your foot down. It's easy to give more credit to that tweak than it's due.. if your needle is wrong, you'll still end up with the wrong mixture at some / all points throughout the rev range regardless of throttle position or idle-mix setting.
That said, it is satisfying when you change the dashpot oil and it goes that much harder, it's tempting to call it fixed :lol:
You'd be surprised how much better it'll go when you just take the carb apart and clean it ;)
PostPosted: Fri Jan 28, 2011 10:24 pm
Nick
Autobarn sell proper SU oil for $10.
Also my HS6 was a pain till it had the top off and was given a clean with carby cleaner spray. Made a big difference once cleaned. The oil was one part, cleaning all the cr@p off was the other. Once that is done I guess you can look closer at needles etc.
Alec
PostPosted: Fri Jan 28, 2011 10:29 pm
thanks Ls i will buy some tomorrow.
yes they are rebuilt twin su's.
just needs a good going over & that will be done tomorrow.
PostPosted: Sat Jan 29, 2011 6:53 am
Mods rock!
Interestingly, the workshop manual (incorrectly) says to use Engine Oil, which is actually OK for most normal driving. The genuine SU oil is straight 20 weight.
PostPosted: Sat Jan 29, 2011 3:33 pm
Hey how did this change into a discussion about dashpot oils. :)
I've tried everything apart from the proper SU Dashpot oil. The best result I've had is from Shell Helix HX3 Multigrade 20-50. I've tried two stroke, mineral and synthetic, auto trans fluid (maybe it depends on the brand because I know alot of people on here use it and it works for them), three different weights of Motul Synthetic fork oil and a couple of other things, nothing worked I still got bad throttle response and inconsistent running. Next time I'm near an auto store I'll get some dashpot oil and give it a go.
Users browsing this forum: Bing [Bot] and 86 guests
