It is currently Mon Aug 11, 2025 2:37 am
PostPosted: Sun Jan 30, 2011 7:32 pm
what would be the best way to tap this into the fuse box on a car?
http://dicksmith.com.au/product/P1679/lighter-panel-socket
what gauge wire, what fuse etc...
Successful Trades: Benjamin, minikook, Gordo, 2 S's and a clubman, mattsmadmini, shadow blue, 1018cc, -=MiniMafia=-, hueylui
PostPosted: Sun Jan 30, 2011 8:09 pm
I'm about to fit one in into my wifes mini which I have already purchased...
It has a 1 meter length of wire so its a matter of cutting off the end and finding the - earth and hard wire it it in to the fuse box.
This is for her GPS...mine will be done the same.
PostPosted: Sun Jan 30, 2011 8:12 pm
Personally, I would run a length of cable to the battery connection on the starter solenoid and put an inline fuse on it. Something around 2.5mm2 for the cable and a 10 amp fuse... Make sure you have a good 'earth' connection to wire the -ve up to and you're all sorted.
PostPosted: Mon Jan 31, 2011 8:06 am
Personally i just spliced the wires running to my AM Radio, and used that +ve and earth.
Since the radio never gets used, a lack of current wouldnt be an issue.
You're so square
Baby I don't care
Users browsing this forum: Bing [Bot] and 109 guests
