For Vicroads it is a little more well defined. Anything pre-adr (1969 for seats it seems) does not require an approval certificate.
Replacing seats
An Approval Certificate is not required for a replacement seat provided:
* the seat is offered by the manufacturer as an option and is replacing and existing seat
* the original seat mountings are used
* appropriate seat belts are fitted.
An Approval Certificate is required if:
* the replacement seat was not offered by the manufacturer as an option
* the vehicle was manufactured on or after 1 January 1969.
For more information about adding seats, see the Vehicle Standards Information No.19 - Additional or replacement seats [PDF 174KB, 2pp]
from the linked PDF for more information:
For vehicles manufactured before 1969 the seat anchorages must be of at least equivalent strength to the original anchorages. A VASS member should be consulted if there is any doubt regarding the strength of the anchorage or any part of the seat installation.
Now under "An Approval Certificate is required if:", it does not state whether it is an AND or OR clause.
GT, there is VERY minimal information in the RTA document, do you have another link which clarifies the non-exemption of pre-ADR vehicles?
From your link:
Owners should ensure that the seat and its anchorages comply with any applicable ADR requirements (possibly by certification from the seat manufacturer or by an engineering signatory) and the appropriate seat belts are fitted to all seating positions.
Vehicle Standards Bulletin No. 5 issued by DOTARS covers requirements for the manufacture of additional seats.
I don't see where it mentions pre-adr vehicles at all?
