It is currently Wed Aug 20, 2025 3:24 am
 Post subject: Help in SA
PostPosted: Tue Feb 01, 2011 11:38 am
Hey there everyone,
I have recently moved to Adelaide for work and don't really know anyone down here or know any of the mini businesses around the traps.
I took the mini for a blast through the hills just after the mini arrived (it was shipped down) and after a few hours of driving, the front passenger wheel got the wobbles. I got out and had a look and two, not one, but TWO wheel studs had sheared/snapped.... Not seen this or heard of this happening before.
I ended up getting the mini towed home and it has sat there for a couple of weeks.
I was thinking of doing the repairs myself, but want a little piece of mind. I am living in the CBD and either need to get it somewhere or remove the hub and install new studs myself. It has just had a new 7.5inch disc set up installed on it so there may have been something there that caused the breakage.
I was thinking of doing all the studs on the front following this incident...
Anyone got any suggestions/thoughts?
Thanks,
Should I get it towed? Remove the hubs and install new studs?
PostPosted: Tue Feb 01, 2011 12:46 pm
its probably not the studs, most likely its the wheel bearings. There not hard to do and arnt that expensive.
PostPosted: Tue Feb 01, 2011 12:51 pm
This space for rent
Sorry, I must be a little dense this afternoon. How does a wheel bearing break the studs?
PostPosted: Tue Feb 01, 2011 12:54 pm
oh i just re-read what happened oops :oops: . i actually didnt read what had happened. My bad. I thought he just had a loose wheel.
Sorry turns01 and sgc
PostPosted: Tue Feb 01, 2011 12:56 pm
:lol:
What type of wheels are you running bro?
PostPosted: Tue Feb 01, 2011 2:08 pm
Yeah the studs were sheared clean off. Lost the wheel nut too...
Running a set of these
http://www.midlandwheels.com/Shop/P-2175-5-x-10-Minilight-Matt-Black-All-Over---Red-Rim--165/70x10-Yokohama-A008.html
PostPosted: Tue Feb 01, 2011 2:17 pm
This space for rent
They look very little different to a Contessa (which is what I run, 10x5).
Are you certain all the wheel nuts were torqued correctly? Have you allowed any grease monkeys to do them up with a rattle gun? These are too big for our widdle studs, and stretch or break them outright.
Likewise, if they were loose then the wheel moving around could easily be enough to break the studs, I've had that happen before :shock:
If I were you I'd be replacing all of them, unless you know they're good...
PostPosted: Tue Feb 01, 2011 2:24 pm
Supercharged
i think studs is a pretty easy job to do at home if you have basic tools?
you can buy the studs online or from a local mini shop
there is newport motors on port road,
or minisport on south road.
morris mania at kent town would be the closest but i think they are closed now?
PostPosted: Tue Feb 01, 2011 2:35 pm
Good job for a BFH!!!!
PostPosted: Tue Feb 01, 2011 2:36 pm
Milatsmadmini
that happened to me once...
my nuts werent tight enough... the wheel went flying down the road in front of me :lol:
as Sgc and supadupamini said, replace all of them, and yes, you can do it at home, hell, i did it on the side of a motor way :wink:
Milatsmadmini
actually will agree with ya on this one Hanra :lol:
I don't really have a work bench at my new place.
Also getting the hub nut off, will that pose any difficulties?
Are there any tricks to getting them off?
Cheers for all your help guys. I will look into those mini suppliers/garages.
Thanks,
PostPosted: Tue Feb 01, 2011 2:46 pm
On the very odd occasion the dribble that comes out of my keyboard actually makes sense.
PostPosted: Tue Feb 01, 2011 2:57 pm
Also said that it just had a set of disks fitted - probably the studs weren't pressed (pounded with FBH) all the way it. Check all the others.
On the side - did you have longer studs and spacered drums fitted to the rear at the same time? - if so check that those studs are pressed all the way in too.
PostPosted: Tue Feb 01, 2011 3:00 pm
This space for rent
I've never belted them all that hard when I've fitted mine. In fact, 9 times out of 10 I do it with the drive flange on the car, and just press them in with a set of vice grips, then tug them all the way onto the splines with a wheel nut and a few washers...
Users browsing this forum: No registered users and 429 guests
