It is currently Sat Jul 26, 2025 5:56 pm
 Post subject: Speedo Drive Gear
PostPosted: Fri Feb 04, 2011 7:46 pm
hi,can i use the speedo drive gear out of a morris 1100 remote gearbox in my clubman rod change box ?
the clubman box has no drive gear in it.if not where can i get one ?
thanks in advance
jayson
PostPosted: Fri Feb 04, 2011 7:54 pm
Mods rock!
Not sure if the Morris one is the same as mini, I think it would be, however best check. The stock Oz mini ones were 17 tooth pinion and 6 tooth spindle.
PostPosted: Fri Feb 04, 2011 8:12 pm
Is same gear in both.
Only the UK fiddled pinion gears, not Oz. :wink:
We just used a heap of different speedos instead.
PostPosted: Sat Feb 05, 2011 2:22 pm
thanks gt,thanks doc,just the answer i was hoping for.
jayson
Users browsing this forum: Bing [Bot] and 84 guests
