It is currently Wed Aug 06, 2025 4:47 am
 Post subject: Don't trust the dots!!!
PostPosted: Tue Feb 08, 2011 12:29 pm
I know that this is mentioned in every cam timing article but last night my new set of MS duplex gears dialed in at 130° ATDC!!!!
WTF!
PostPosted: Tue Feb 08, 2011 5:34 pm
Mods rock!
WTF!
Sounds a whole Cam Tooth out.
PostPosted: Tue Feb 08, 2011 6:08 pm
1 tooth = 18°.
It's easy to be out 1 tooth unless you are careful. I hang the big sprocket below the small one in the chain before fitting, and put a straight edge through the 2 sprocket centres and the dots...
PostPosted: Tue Feb 08, 2011 10:58 pm
use a big degree disc on the flywheel and set the cam timing up to the degrees that the valves open at. Turn the engine in direction of travel to eliminate any chain slack.
It's the only safe way to do it. You are right NEVER TRUST THE DOTS
www.minisprintgt.com
 Post subject: Dots !!!
PostPosted: Wed Feb 09, 2011 7:26 am
When I rebuilt the Diesel engine in my Ford Van I experienced this. We thought there was something wrong with the newly rebuilt injector pump as the engine was starting and running very rough and smoking like diesel was not getting burnt correctly. Further checking revealed that the markings on the pump drive gear was on the next tooth so timing was wrong even though the marks were all lined up. I lined it up as per compression and inject stroke (one tooth out) and ran like a charm. 16 years later and it is still going like a train.
"Let us remove your "SHORTS"
PostPosted: Wed Feb 09, 2011 11:17 am
Yep, that's what I did, moved chain one tooth. You would think they had a jig for that or something.
I used the big protractor and push-rod method
Anyway I've got an offset woodruff key on its way.
PostPosted: Wed Feb 09, 2011 1:08 pm
Mods rock!
Doesn't hurt to set it at an inital 1 to 2 deg. advanced to allow for chain wear.
