It is currently Sat Jul 19, 2025 2:33 pm
PostPosted: Thu Feb 10, 2011 11:57 pm
Hi,
I Have been trying to fit a new ali radiator in my mini, though I am having a lot of trouble with the bottom radiator cowling coming into contact with the crankshaft pulley.
Has anyone experienced this before?
I have even taken an angle grinder to it with no avail.
Personally, by cutting the cowling and trying to bend the bottom mounting bracket I think I have made it worse.
If anyone has any ideas it would be appreciated.
Perhaps I need to start over with a new bottom bracket and cowling. I live in Perth, if anyone can asisst with a good s/hand item it would be appreciated.
Thanks
Roc
PostPosted: Fri Feb 11, 2011 4:29 am
Mods rock!
There were 3 different bottom brackets and 2 different cowls that I know of. Perhaps the ones you presently have off-set it all the wrong way. Might need to go lookin' for some different ones.
PostPosted: Fri Feb 11, 2011 8:41 am
I have a spare Clubbie set if you need it.
PostPosted: Fri Feb 11, 2011 9:01 am
I remember having the same problems until I realised I was trying to use a clubby bottom bracket in a roundie. :oops:
Is it a standard radiator or is it wider than the old one?
Do you have an A+ engine with the breather can on the timing cover?
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Sat Feb 12, 2011 7:58 pm
i had a similar problem and so i slotted the holes in the bottom bracket
