It is currently Fri Jul 18, 2025 5:34 pm
 Post subject: Starter motor
PostPosted: Fri Feb 11, 2011 7:50 pm
I have just replaced the starter motor....The one I took out had a broken spring...looks like it broke very recently.
My question is....How easy is it to replace the spring?
PostPosted: Fri Feb 11, 2011 7:55 pm
Mods rock!
Easiest done with the spring compression tool, then actually very easy. Without the tool, you may get it apart but I doubt you'd be able to re-assemble. Usually, when the spring goes, it's also a sign that the pinion is alo about to split and the bendix is worn.
PostPosted: Sat Feb 12, 2011 5:29 am
AND DON"T FORGET THAT I HAVE SOME OF THESE BENDIX SPRING TOOLS STILL AVAILABLE FOR SALE. $45 post free.
Email me if you need one. [email protected] I specialize in these hard to get Mini Electrical things. :wink:
"Let us remove your "SHORTS"
