It is currently Sat Jul 26, 2025 6:50 am
PostPosted: Sun Feb 13, 2011 1:59 pm
I'm putting my motor together - I've never put gasket goo on the oil pump gasket, but I think I read somewhere that some people do it...
advice from the gurus?
PostPosted: Sun Feb 13, 2011 2:07 pm
Mods rock!
If it is an ordinary paper gasket (without some rubbish coating) then it shouldn't matter either way. I usually do use goo just to be sure.
PostPosted: Sun Feb 13, 2011 4:06 pm
I'm not a fan of silicone gasket stuffs here, in case a squeezed out bead gets into the oilway, but I like a bit of Loctite No.3..
It costs nothing...
PostPosted: Sun Feb 13, 2011 5:42 pm
It costs nothing...
Me too. :wink:
PostPosted: Sun Feb 13, 2011 5:44 pm
It costs nothing...
Me too. :wink:
Yep, number 3 for me too.
PostPosted: Sun Feb 13, 2011 6:36 pm
thanks guys
I can never find my little bottle of #3... it blends in with all the other black gooey things in my garage
PostPosted: Sun Feb 13, 2011 7:10 pm
I don't use anything, even if it leaks it won't lose much and a small oil leak on the inside of the engine doesn't matter.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Sun Feb 13, 2011 8:10 pm
If it leaks on the suction side it may get an air lock in the pump when it is parked.
If it leaks on the pressure side it will reduce the available pressure.
Either way it won't matter. :lol:
PostPosted: Mon Feb 14, 2011 4:14 pm
Never used any goop on the oil pump gasket, just made sure both surfaces are spotless.
Never had any oil pressure issues...
Jacob
 Post subject: oil pump gasket goo
PostPosted: Tue Feb 15, 2011 8:02 pm
Just another idea you could use some avaiation gasket goo/ permatex i found it to work well on all paper gaskets but as the other have said use it sparingly as you dont want to squish the excess out everywhere and possibly interfer with anything
wade
1971 LEYLAND GT
PostPosted: Tue Feb 15, 2011 9:14 pm
Permatex #3 aviation cement is now called Loctite #3. Same stuff in the same bottle with the same brush. :wink:
