It is currently Sat Aug 09, 2025 8:17 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 214, 215, 216, 217, 218, 219, 220 ... 568  Next
PostPosted: Tue Feb 15, 2011 9:23 am
yesterday replaced the right hand door seals, window seals and re-aligned the door.
now the left side next.
1275LS nugget gold
GSX-R1000 K5
Ducati panigale s (carlos checa replica)
PostPosted: Tue Feb 15, 2011 6:01 pm
Changed the 92C thermostat to a 82C one, at the same time put on a proper 1275cc top radiator hose.
Loaded up the latest firmware for the MegaSquirt ECU, of course the car wont start now! :evil:
Edit: Found problem, all OK now! :D
PostPosted: Tue Feb 15, 2011 7:30 pm
hung some new doors
fitted new door handles
rivetted a new roof on
vacuumed, steam cleaned
general clean up
oh hang on that was around the house, no time to work on the mini!
tim
PostPosted: Tue Feb 15, 2011 9:01 pm
Took 1275LS for rwc and now ready for reg :)
1978 1275 LS silver 3rd palce mini Oz50 LS,SS,GT Class
1970 MORRIS MINI K 1100 3rd place mini50 pre '71 Class
Rover BBQ..... ;)
PostPosted: Wed Feb 16, 2011 10:13 am
This space for rent
Rolled it out of the way (again) so I could work on the Hilux (again).. this time replacing a brake hose and overhauling a caliper.
Must say I'm rather pleased with this effort, one of the 4 pistons was properly seized. Didn't want to fill the thing up with grease (which I didn't have enough of anyway) to force it out, so I used the Mick Special Design hydro pump instead. 500psi of glycol into the argument had the stuck piston out easily :D Much easier to clean out the caliper afterwards, too... 8)
I think the Mini's getting jealous of all the attention I'm giving to the 'lux.. when I started her up to get back into the garage, she ran like a pig :(
PostPosted: Wed Feb 16, 2011 10:56 am
Fixed (hopefully) the tailights not coming on, as well as the interior light.
I have completely re-done my AFR and VE tables in the MegaSquirt, so I've been out and about "Auto Tuning" it, again. Currently sitting in Maca's down in Point Cook feeding my face! 8)
PostPosted: Wed Feb 16, 2011 6:55 pm
Just finished replacing wheel bearings (inner and out) and four ball joints.
Since light travels faster than sound, people appear bright until you hear them speak
PostPosted: Wed Feb 16, 2011 7:55 pm
Rebuilt the mokes front subframe mount!
Was actually a lot of fun
You're so square
Baby I don't care
PostPosted: Sun Feb 20, 2011 6:14 pm
Bodywork. I'd painted the front and roof, then realised the RHS guard had bog in it for a reason - a few ripples and dents which looked heinous. So I stripped the guard and bogged it. And I hate bog as much as I hate plastering a wall; I just struggle. But I persevered and now it's pretty much there. This time I'll primer it and guide coat it before I put the colour on.
PostPosted: Sun Feb 20, 2011 6:27 pm
This space for rent
Finally gave it the attention it deserved. Oil / filter change, cleaned the carbs & plugs, new air filters, tweaked the mixture, flushed & replaced the coolant and adjusted the clutch.
Still need to grease all the nipples, adjust the rear brakes, flush the brake & clutch fluid, degrease the engine and give it a good clean.. another day :lol:
Pulled out the front seats ready to put in new carpets. Will have to get rid of some rust and reprime beforehand though. Any suggestions on what to use as underlay as the old hessian was stuffed?
PostPosted: Sun Feb 20, 2011 6:37 pm
Picked up my r/h tank, stripped out the boot ready for the install.
PostPosted: Sun Feb 20, 2011 8:06 pm
Milatsmadmini
welded in a few patches, all looking happy now :)
found another one, near the rear subframe mount point, gonna need to get a nice big plate for that one...
hopefully paint this week...
PostPosted: Sun Feb 20, 2011 8:42 pm
Spent another few hours profiling camshafts and checking valve geometry.
Not long now and I can do the final engine build :D
Jacob
PostPosted: Mon Feb 21, 2011 12:22 am
cleaned it out, reinstalled back seat, ready for her trip up to newcastle...
tim
Users browsing this forum: Bing [Bot] and 72 guests
