It is currently Sat Jul 26, 2025 1:49 am
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3
PostPosted: Fri Apr 08, 2005 7:38 pm
Hey thanks all for the info - might go and have a chat to the local guy next week
PostPosted: Fri Apr 08, 2005 8:14 pm
resident alien
resident alien
fruity wrote:
J_A_M wrote:
:evil: blow me
Err ummm.. I think you'll need one of Marvin's 'help line' numbers for that sort of help :wink: :lol:
But you're the only one I call fruity... honest!!! :shock:
PostPosted: Fri Apr 08, 2005 8:27 pm
:shock: Hey I'm a good wholesome catholic girl, Marvin..
PostPosted: Fri Apr 08, 2005 8:32 pm
resident alien
resident alien
I know, I know... :)
Everyone please note: fruity is a wholesome catholic girl :wink:
PostPosted: Fri Apr 08, 2005 11:22 pm
Bromley wrote:
Are you going to minis on the Murray this weekend Gafmo?
Sorry I wish :roll:
PostPosted: Fri Apr 08, 2005 11:25 pm
czerial wrote:
fk Gaf, didnt relise the van is so major!, how did you lift it straigh up in the air like that :shock:
Not sure what you are talking about...under side of the rear...I just jacked it up Axle stands and then Bricks and jacked it up again and then raised the Axle stands...If it's the front I used the engine puller :lol:
PostPosted: Fri Apr 08, 2005 11:29 pm
CLM wrote:
Yeah blasting causes holes in thin spots, but then again so would a probe if you had checked there for rust ;)
There are different types of blast medium, from sand to soda to ground nut shells, the softer ones won't harm the metal as near as bad as sand. The biggest thing you want to worry about in blasting is metal deformation on the really large unsuported areas (like the rear quarter panels ;) ) any holes it finds are holes that should be repaired irregaurdless if you manually strip it or it's blasted.
Oh yeah, another big negative with blasting! dist and debris filtering out of the nooks and crannies spoiling paint jobs and making a general nuisance for a long time after the blasting unless the car is meticulously cleaned right after blasting! :D
You should try wire wheeling and how black you are afterwards...I had crap comming out of my nose for three days each time :lol: :? and that was with the mask on :shock:
PostPosted: Sat Apr 09, 2005 4:14 pm
I can definately confirm this.......Wear a long sleeve shirt aswell....If you have hairy arms its rather painful getting the gunk out of your hair :lol:
Gaf Ive sent you a pm..... :P
[Maverick] 1971 Mini K
PostPosted: Sat Apr 09, 2005 7:01 pm
:wink: replied
Users browsing this forum: Bing [Bot] and 95 guests
