It is currently Sat Aug 09, 2025 8:06 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 215, 216, 217, 218, 219, 220, 221 ... 568  Next
PostPosted: Mon Feb 21, 2011 9:36 am
This space for rent
Drove it to work this morning, gee what a difference a service (read: clean carbs) makes :D Running and sounding sweeeet 8)
PostPosted: Mon Feb 21, 2011 7:02 pm
I put slightly bigger main jets (160>168) in the 45 Dellorto.
More responsive now, so I might try 175s too.
PostPosted: Tue Feb 22, 2011 8:30 am
Did a service on the Mini Deluxe last night and I think I have discovered a stuffed bearing in the diff. :shock:
Guess I will lift out the engine in my spare time and check out the damage. Gearbox rebuild is only 12 months old, so a bit disappointing.
Also discovered the steering column is slipping on the new UK steering rack.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Tue Feb 22, 2011 8:30 pm
Replaced the 40 year old cracked and broken plastic speedo surround on my Cooper S with another 40 year old uncracked one.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Tue Feb 22, 2011 8:34 pm
started it.....Hahaha :lol:
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Tue Feb 22, 2011 8:54 pm
One step forward....2 steps back!
Got the temp gauge working perfectly as well as the fuel gauge - Wombat's magic regulator and a new temp sender....
Car ran like a pig as the throttle linkage nuts were not tightened properly, so balance the carbs again, wash and polish for Sunday at Zetland.....
Cooper S Mk2
Cooper S Mk1
PostPosted: Tue Feb 22, 2011 8:57 pm
Got the engine in the clubby today
It's looking sweet.
PostPosted: Wed Feb 23, 2011 11:52 am
Milatsmadmini
four 10x6" steelies are currently in the sun with a half tin of paint stripper between them slowly lifting years old paint in prep of going Matte black with some A008's.... nom!
PostPosted: Wed Feb 23, 2011 8:58 pm
Well on Monday, Tuesday and today, hauled the green car from FNQ to NSW, will get to Goulburn tomorrow. Slight hiccup with the trailer today, otherwise no drama on the trip. Looking forward to Oz50.
Steve
PostPosted: Wed Feb 23, 2011 9:36 pm
Finally started to assemble the engine for my project, fitted the pistons into the bore and torqued up the bearings. Its now starting to look like an engine.
1969 Cooper "S"
1967 Mini Deluxe
PostPosted: Wed Feb 23, 2011 10:55 pm
Found the origin of a large puddle of fresh water that was pooled under the van. It came from two leaking emergency water bottles I had stashed in the speaker boxes. :oops: :roll:
Image Image
PostPosted: Wed Feb 23, 2011 11:17 pm
Stripped the threads on the rocker Studs :x
2008 Prado GXL
PostPosted: Thu Feb 24, 2011 8:38 am
Do do list for Sunday:
Wash
Wax
Chrome polish bright work
Vacuum
Oil change
Grease nipples (mmm greasy nipples)
Check tappet clearences
Top up fuel (8 or 12 weeks old)
Tyre pressures
Put in child seat
Pack toys, mats, lunch
See you all Sunday!!!
PostPosted: Thu Feb 24, 2011 6:55 pm
Wash
Wax
Vacuum
Oil change
Tyre pressures
Put in child seat
Don't forget the Armorall :)
Wish I could be over there :( :cry:
PostPosted: Thu Feb 24, 2011 9:11 pm
Started the Cooper S, moved it out of the garage then washed it ready for Sunday. :)
1969 Cooper "S"
1967 Mini Deluxe
