It is currently Mon Jun 30, 2025 10:00 pm
PostPosted: Sat Feb 26, 2011 5:22 pm
Die Die Die!!
when i apply my brakes they shudder.. can you tell me what the problem is ?
- the car is a Rover 1988 with all mid 90's running gear and a late 90's Subframe
- the car was in a minor RHS front quarter accident around 5 months ago (but has been fully fixed since)
- the car has been wheel aligned within 2 weeks
- has had new shocks/calipers/pads within the last 4 months (with no sporty driving ie. they shouldnt have gotten boiling)
- the ball joints and tie rod ends are fine (been checked/adjusted within the last 2 weeks)
- you can feel it through the pedal
- you can feel it through the steering wheel slightly
my only guesses are
- wheel bearings ?
- wheel balance ? (wheels are brand new -2 weeks old)
- somehow the calipers have warped within the last 4 months?
any help would be much appreciated
Nick
PostPosted: Sat Feb 26, 2011 5:29 pm
Mods rock!
Maybe a disc has warped or a brake drum has bent?
Had some gorilla do up the rear wheel nuts (to tight) of late?
You can check it with a dial gauge or if you don't have one, a bit of bent wire and a good eye will do the same.
To check the drums, take them off and put them back on reversed, be sure to put the screws in to hold them in the right place.
PostPosted: Sat Feb 26, 2011 5:37 pm
Die Die Die!!
its quite possible they have done the rears up too tight.. the fronts could be warped but i have had them replaced just before the accident..
the wobble definatly feels like its comming front the front wheels...
PostPosted: Sat Feb 26, 2011 5:50 pm
If the steering wheel shudders as you brake, then its in the front, but if its only in the pedal, then it's most likely the rear.
PostPosted: Sat Feb 26, 2011 5:56 pm
Die Die Die!!
was in the front before i got the ball joint adjusted and the wheels aligned.. but its MUCH better now..
ill double check it then..
PostPosted: Sun Feb 27, 2011 2:23 am
Die Die Die!!
its just the pedal as far as i can tell..
ill have to get the rear brakes checked out
PostPosted: Sun Feb 27, 2011 8:48 am
Put new pads in recently?
PostPosted: Sun Feb 27, 2011 10:36 am
Die Die Die!!
yeah pads and calipers around 4-5 months ago
PostPosted: Sun Feb 27, 2011 11:01 am
Just out of curiosity, what are the pads?
PostPosted: Sun Feb 27, 2011 2:33 pm
If it is just in the pedal it could be the rears.
I had a similar problem and found that the drum was not centering on the axle.
Found the studs were a loose fit in the drum holes.
These were new spaced drums.
Fixed it by spinning the drum and observing the out of round.
Used a rubber mallet and tapped the drum on the side to centre it then tightened up the retaining screws.
Wheel back on and all OK.
I susspect there are different wheel studs, some of which are a snug fit in the drum, holding it in the correct place.
PostPosted: Sun Feb 27, 2011 11:25 pm
Die Die Die!!
they are EBC Green stuff
and i need to get the rears checked out as my handbrake needs tightening, i was told you cant simply tighten it and that the rear brakes are probably worn or need attention
PostPosted: Mon Feb 28, 2011 7:26 am
Simple but over looked thing, check the wheel nuts are all tight and caliper bolts are tight too.
Now with 2 extra ports!
PostPosted: Mon Feb 28, 2011 7:34 pm
i'd be guessing the rear brake drums are warped or worn unevenly
PostPosted: Tue Mar 01, 2011 11:28 pm
Die Die Die!!
after driving too and from work today, i can definatly feel the shudder through the steering wheel and pedal
PostPosted: Tue Mar 01, 2011 11:34 pm
Have you had them really hot?
I suspect warped rotors.
