It is currently Sat Jul 19, 2025 3:48 am
Post new topic Reply to topic  [ 18 posts ]  Go to page Previous  1, 2
PostPosted: Sun Feb 27, 2011 8:23 pm
Mods rock!
david rosenthal wrote:
mini7boy wrote:
I'm not happy with the way I worded this last sentence in my second posting(above) on this thread.
I said: "There may be reasons why a 940 head is not a good choice of head for a given 998 engine, but the need to pocket the block isn't one of those reasons."
I could have better conveyed the thought I intended by instead saying:
"There may be reasons why a 940 head is not a good choice of head for a given 998 engine. It may be that a given 12G940 head has ports and/or valves that are too large to support good port velocity on a 998 engine that is of a fairly mild build spec. The head may also have been skimmed too much to allow a suitable compression ratio or room for an adequate amount of cam lift. But, a 12G940 can be used successfully on some 998 engines without the need to pocket the block."
I found a 940 head bolted to a stock 850 engine . it worked but a waste of a good head.
As for port velocity you can have low velocity and high volume flow, or high velocity and low volume flow. So what is better. What ever the head is "flowed at" does not mean much if you have a variable flow restrictor in the system.
On the subject of valves consider the shape of the combustion chamber and the amount of valve shrouding it has. This also has a BIG influence on air directional flow into the cylinder.
I have used cylinder heads on my performance 351 V8's that were "U beaut" flow tested and they would not pull the skin of a rice pudding, yet other heads had less "maximum flow' and left them for dead.
With any performance engine it's a balancing act to get everything to work.
In other words (fewer words?), Flow is not everything, it's only part of it :wink:
PostPosted: Sun Feb 27, 2011 9:02 pm
No apology is necessary, mattsmadmini. This is just an exchange of information and opinions. As long as everyone is clear on the differences between those two, the can be no problems.
As to the remark "Flow is not everything, it's only part of it", I don't remember seeing where anyone had written that flow is everything.
I started this thread merely to inform readers that there is information available for a subject that seems to be in great demand. The questions surrounding putting 12G940 heads on 998 blocks seems to crop up quite frequently on all of the forums. I never intended to spark a debate about which heads are better for the 998, etc. In no way did I suggest that any one head casting is better than another for the 998.
"it's always better to be uninformed than ill-informed"
PostPosted: Mon Feb 28, 2011 6:41 am
Mods rock!
Maybe not in this thread but that is the usual 'fixation' when someone modifies a head.
