It is currently Sun Jun 29, 2025 8:24 pm
Post new topic Reply to topic  [ 21 posts ]  Go to page Previous  1, 2
PostPosted: Mon Feb 28, 2011 11:23 am
Mods rock!
76van wrote:
edit: further to the above,when i have the dissy wire on the coil there is no power at -ve on the coil but when i remove the dissy wire i have power.
many thanks
jayson
Right, coil is OK then. Are your points opening?
PostPosted: Mon Feb 28, 2011 11:34 am
yep points are opening.
could it be earthing out through the dissy ?
i have the dissy off my 1275 do you think i should try that ?
thanks again for your help
PostPosted: Mon Feb 28, 2011 1:35 pm
Mods rock!
Yeap, for some reason it is (shorted through the dissy). Maybe try your 1275 one, but maybe not a good idea to leave it in there. Be sure to mark the position of your old one so as the timing doesn't end up too far out.
A very common cause for the dissy to be shorted is the insulating washer on the points, where the hex nut holds the dissy wire to them is missing or cracked, so check that the washer(s) are there. Sometimes the condensor can also go 'shorted'.
PostPosted: Mon Feb 28, 2011 2:01 pm
thanks gt.
tried the 1275 dissy & had power at -ve on coil with points open but can`t use it as it`s a 45d4 which i found out is an a+ dissy.
so new 45d on it`s way from mini king.
thanks again for all your help
jayson
PostPosted: Mon Feb 28, 2011 2:43 pm
Hey Jayson,
You would of probably found that the problem was cheaper than a whole new distributor, but oh well glad you are on your way to getting her running!
Cheers, Sam
PostPosted: Tue Mar 01, 2011 6:36 am
thanks sam,was going to upgrade to 45d dissy anyway so no problem there.
jayson
