It is currently Sat Jul 05, 2025 9:41 pm
Post new topic Reply to topic  [ 23 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 02, 2011 6:31 am
Die Die Die!!
i havnt really pushed the car no.. its seeming the logical thing though
PostPosted: Wed Mar 02, 2011 6:37 am
Mods rock!
There have been a spait of after market discs and some drums for all types of cars - world wide getting about that were not normalised or stress relieved after casting and before machining. So when they are first fitted they are fine, but once they get warm or hot they relieve and so take up their relaxed shape, which will be different to that to which they were machined to - warped.
So, the best way to find out
GT mowog wrote:
Maybe a disc has warped or a brake drum has bent?
Had some gorilla do up the rear wheel nuts (to tight) of late?
You can check it with a dial gauge or if you don't have one, a bit of bent wire and a good eye will do the same.
To check the drums, take them off and put them back on reversed, be sure to put the screws in to hold them in the right place.
PostPosted: Wed Mar 02, 2011 9:38 am
One problem that I had when installing brand new disc brakes was that the disc and subsequently the drive flanges were not seated properly on the hub and CVs. Could only figure this out with a dial gauge set up to see if it was spinning true or not.
Beware! cause this cause the hub nut to become loose with time, luckily I caught it quickly and fixed it. Get it fixed, pronto!
Lillee - 1969 Morris Mini K
PostPosted: Wed Mar 02, 2011 10:05 am
Warped discs i rteckon, ive felt the same thing in my HSV, new discs lasted 2 months
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Wed Mar 02, 2011 10:36 am
You realise ofcourse now that your car has them fat ass wheels on it the brakes have to work a bit harder to make you stop in the same time?
PostPosted: Wed Mar 02, 2011 5:39 pm
Die Die Die!!
yeah i realise that.. but when your brakes are impared because the wobbling comming from the brakes/wheels they dont stop good either :S
PostPosted: Mon Mar 14, 2011 10:08 am
666, did you sort your brake shudder out?
What did you find?
PostPosted: Mon Mar 14, 2011 10:35 am
Die Die Die!!
No I Havnt yet, I haunt had the time or money, possibly this fortnight though :)
Users browsing this forum: No registered users and 65 guests
