It is currently Fri Jul 25, 2025 10:32 pm
PostPosted: Wed Mar 02, 2011 5:17 pm
can someone please post me a good pic of leads coming out of the distributor and which cylinders they lead to.
much appreciated.
PostPosted: Wed Mar 02, 2011 5:23 pm
Starting at 2 o'clock on the dizzy & going anticlockwise
1-3-4-2
with 1 being the radiator end.
PostPosted: Wed Mar 02, 2011 6:22 pm
That is of course if the distributor is in the "right" spot.
PostPosted: Wed Mar 02, 2011 6:50 pm
And if it is not in the right spot don't, what ever you do, don't try to remove the distributor drive and drop it into the sump.
PostPosted: Wed Mar 02, 2011 6:53 pm
That made me throw tools everywhere :evil:
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Wed Mar 02, 2011 8:48 pm
unless you screw a long 5/16 unf bolt in first
PostPosted: Wed Mar 02, 2011 9:24 pm
Magnet on telescopic rob works a treat :D .
2008 Prado GXL
PostPosted: Thu Mar 03, 2011 4:18 pm
There is no real need to remove it if it has been fitted wrong.
Just stick the leads where they need to be and not where they are supposed to be and it will all work perfectly.
PostPosted: Thu Mar 03, 2011 6:03 pm
A couple of yers back i wrote a very long treatise on how to set up the timing on a mini. It was from the distributor drive, getting top dead center, aligning the distributor and the n positioning the leads.
I dont have the band width (flakey satellite internet) to search for it but if someone else can it may help here. It certainly mentions the ways to avoid dropping the drive into the sump.
Mike
Users browsing this forum: Barkfast, Bing [Bot] and 107 guests
