It is currently Sun Jul 27, 2025 11:45 pm
 Post subject: old fuel in tank
PostPosted: Wed Mar 02, 2011 5:15 pm
its almost time to fire up the mini for the first time in 18 months, now the recon'd engine is in.
There's petrol in the tank, but it's been sitting there for, well, 18 months!
Should I drain and replace before I try firing it up? Or will it be fine?
PostPosted: Wed Mar 02, 2011 5:19 pm
If it's that old I'd replace it
David L
Mods rock!
Drain it. It ain't worth the risk.
PostPosted: Wed Mar 02, 2011 8:42 pm
Poor old victa lawnmowers usually cop that stuff..
PostPosted: Wed Mar 02, 2011 8:56 pm
This space for rent
Used to be you could leave fuel that long and it'd be fine, but these days all the good stuff evaporates and you're left with what may as well be 50 RON water...
PostPosted: Wed Mar 02, 2011 9:06 pm
I'd make sure you have a new fuel filter on it as well, cheap insurance.
PostPosted: Wed Mar 02, 2011 9:41 pm
Hey Aussie,
Could also bleed the old fuel out with some new fuel before you put a new filter on if you do, that way its not coping crap fuel straight away and you would clear the last of any built up gunk and what not with that fresh fuel.
Cheers, Sam
PostPosted: Thu Mar 03, 2011 8:48 pm
Just drop in some fuel saver, nulon and the usual suspects make it. sure it wont be race fuel but it wont do any damage.
PostPosted: Thu Mar 03, 2011 8:52 pm
Definitely drop the existing fuel.
Without a doubt or any second consideration.
Using compressed air, gently blow your fuel back towards the tank - take the line off after the fuel filter and go from there.
New fuel - new filter.
No worries!
PostPosted: Thu Mar 03, 2011 8:56 pm
18 months....its no good :!: Drain it including fuel filter and use the fuel as a degreaser thats all its good for. replace fuel filter and refill tank and I would also replace oil filter and oil also
PostPosted: Thu Mar 03, 2011 8:57 pm
Sniff da petty.
A few blokes up Hanra's way might be interested in it.
As gafmo said, use it for parts cleaner!
PostPosted: Thu Mar 03, 2011 9:13 pm
I would totally agree with dumping it but I had an interesting experience with a ford ute that sat for eighteen months waiting for a another engine.
It started first go with the old fuel, the only problem was the fuel filter was almost clogged with a muddy substance but it still ran alright.
Just before it blew it's head gasket, it had been fueled up with 98RON
and an injector cleaner.
So I think the injector cleaner may have preserved the fuel. When the tank was down to half we topped it up but even before that it still ran ok.
PostPosted: Thu Mar 03, 2011 10:06 pm
Thought so guys. Will drain it tomorrow.
Might even see if the thing starts up too :)
PostPosted: Thu Mar 03, 2011 10:21 pm
I know fuel left in mowers for that long need a carby over haul mainly them victas with there tap left on and the fuel goes like a varnish and clogs the jet
PostPosted: Thu Mar 03, 2011 10:36 pm
Tomboss Breweros
Smell it, stale fuel smells disgusting.
How much is in it? if there isn't much (less than 1/4) i would just fill it with fresh fuel, take the line off the carb, pump a bit out by cranking then hook it all back up and off you go.
The mini that i'm tidying up sat for 17 years, i set up a gravity feed of fresh fuel and had a long hose from the pump to a 20l tin. I ran it on the fresh fuel which pumped the tank and lines dry, then i tipped in a bit of fresh fuel to flush it through. Filled it, new filter, no problemo,
kimini wrote:
Jimmyinamini wrote:
