It is currently Wed Jul 23, 2025 6:37 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 05, 2011 8:01 pm
1LRJ15.8 is the bottom one (outrigger bearing).
13H7848 is the idler gear one (in a 4 synchro box). I always replace both sides together.
PostPosted: Sat Mar 05, 2011 8:11 pm
Both meaning engine side as well? Same bearing? (total n00b when it comes to this, gotta start somewhere!)
PostPosted: Sat Mar 05, 2011 8:37 pm
Yep they are a pair. :wink:
PostPosted: Sun Mar 06, 2011 12:51 am
Poeee the gear box you have is that a 4 syncro rod or remote shift. The case I am sending over is off a rod shift and the needle roller bearing in the case is 1 1/16" OD [torrington SCH 12 12] and the one that fits into the gear box is 1"OD [ch1212] Both are same bore 3/4" and same length 3/4".
Don't worry about the needle brg in the case as I have a few new ones and will fit it before I send it over.Should be able to post it on monday before the funeral.
www.minisprintgt.com
PostPosted: Sun Mar 06, 2011 9:44 am
Cheers mate. You're too kind!
Users browsing this forum: Steam, watsupskip and 97 guests
