It is currently Wed Jul 23, 2025 2:23 am
 Post subject: crankshaft pulley bolt
PostPosted: Sat Mar 05, 2011 4:40 pm
Hi Guys, I`ve just put my timing cover back on and also my crankshaft pulley bolt. According to the gregories manual the bolt needs to be torqued to 70 lbs ft, I think it is. How do you stop the crankshaft from turning as you tighten the bolt ??
Jethro
PostPosted: Sat Mar 05, 2011 5:09 pm
Jethro
I have a piece of fly wheel ring gear cut to size to fit in the starter motor hole, drilled with a bolt through the side. put this in so the ring gear teeth mesh, so the fly wheel turns, the bolt hits the casing, no more turny turny.. :D
tim
PostPosted: Sat Mar 05, 2011 5:42 pm
Just sit an old main bearing shell in the ring gear, in the starter hole. It won't slip.
Otherwise, get your sexy (or not) assistant to hold a BF screwdriver in the ring gear... firmly. :wink:
PostPosted: Sat Mar 05, 2011 6:11 pm
Big ass screwdriver works a treat :D
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Sun Mar 06, 2011 11:31 am
big screwdriver sound good. Thanks guys.
Users browsing this forum: XMK870 and 80 guests
