It is currently Sat Jun 28, 2025 6:14 pm
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 9, 10, 11, 12, 13, 14, 15  Next
PostPosted: Thu Feb 17, 2011 1:49 am
When did this Forum become "AusSprite"? Maybe next time we can get a Mini crankshaft tested... :wink:[/quote]
it's only a north /south engine ,so it deserves getting the chop.
www.minisprintgt.com
PostPosted: Mon Mar 07, 2011 4:57 pm
Mods rock!
The results are in.
I have sent them to GR out of curtesy for his perusal and will post them up here shortly.
This has been a bit more drawn out than all of us would have liked, there were a few delays, not the least of which was Australia Post.
Just a brief recap on what this was all about;-
The claims:-
GR wrote:
......... which BMC did by getting the nitrideing in as deep as they did .060 to stiffen the crank, try telling these heat treatment people today how deep it is and listen to there answer they just tell you your all BS.
Graham Russell
and;-
GR wrote:
the hardning went in .080 so they still had nitriding when the crank was ground .080 under size
Graham Russell
and;-
GR wrote:
You went on about not being able to nitride steel with out chromium in it but you forgot about the most IMPORTANT PART for NITRIDEING that is ALUMINIUM for this is what the nitriding follows in to get the depth with out it it will just sit on the top of the steel also if you have any NICKEL in the steel it will reject the nitriding.GRaham Russell
The doubt;-
GT mowog wrote:
I'd like to see that!
The offer;-
GR wrote:
Hi GT MOWOG
I have the piece of crank here come down and get it and you have the depth checked by some body as i have, they measured it at .060 tho. deep.
Graham Russell
The challange;-
TheMiniMan wrote:
so,,, GR , send the sample
GT, test the sample
The test parameters;-
GT mowog wrote:
I will instruct Sydney Mechanical Testing Laboritory to;-
i) Record the name of the person delivering it or the Consignment Note Number.
ii) Photograph and generally describe the sample, including anything distinguishing on it.
iii) Test the core material to determine the grade of steel and its hardness.
iv) Test the surface hardness.
v) Test hardness at 0.005" , again at 0.010", again at 0.015", again at 0.020", at 0.030", at 0.060" and at 0.080".
vi) Determine what (if any) treatment and method of treatment has been carried out.
vii) Prepare a report with all of the above information / results.
If you do not agree or feel there is something else that should be done or tested, by all means, speak up.
I will post the Test Report here, what ever the results.
Do we have an agreement?
The acceptance of the agreement;-
GR wrote:
Whooops sorry no i don't object
Graham Russell
and so, above all else, remember;-
Mick wrote:
Keep it civil.
PostPosted: Mon Mar 07, 2011 5:32 pm
:shock:
I am trying to work who I am going to put my money on! :?
PostPosted: Mon Mar 07, 2011 5:40 pm
owen1975richard wrote:
:shock:
Are we running a book? :shock:
What odds are we looking at?
PostPosted: Mon Mar 07, 2011 6:50 pm
Mods rock!
:shock: WOW there is some interest in this topic, nearly 100 views in the last hour and a bit.......
OK, all measurements are in metric, so to help out, here's a quick conversion table
Metric Imperial (to the nearest thousandth)
50.80 mm 2.000"
41.24 mm 1.624"
0.15 mm 0.006"
0.25 mm 0.010"
0.35 mm 0.014"
0.45 mm 0.018"
0.55 mm 0.022"
0.65 mm 0.025"
0.75 mm 0.030"
0.85 mm 0.033"
(25.4000 mm = 1.000 inch)
So.........
From the measured jounal diameters, the crank has not been ground.
Any useful depth of Nitriding is all over between 0.006" and 0.010", although by definition is stated to have a 'case depth' to 0.022". So, no matter how you want to look at it, the Nitriding does not go anywhere close to 0.060".
By formula composition, EN40A does contain Nickel and does not contain any aluminum.
The sample as tested contained Nickel and very small traces of Aluminum.
PostPosted: Mon Mar 07, 2011 7:05 pm
GT many thanks for arranging for the tests and posting the results, which speak for themselves when you can see that the hardness is pretty much back to base levels somewhere between 0.45mm & 0.55mm.
When you convert it looks an awful lot like 0.020"!
Not only does it have traces of Al but titanium too! :lol:
cheers,
Jacob
PostPosted: Mon Mar 07, 2011 7:10 pm
NO WAY!
You'll have to excuse me Jacob apparently I "Have some dents to pull" :wink:
:lol:
PostPosted: Mon Mar 07, 2011 7:26 pm
well there you go....
thanks GT
Kevin
PostPosted: Mon Mar 07, 2011 8:23 pm
Great work GT Mowog. It is about time we got some proper information rather than " If sound like I know everything, people will belive it as gospel" comments.
Well done.
Have a Nice Day.
PostPosted: Mon Mar 07, 2011 10:17 pm
HAHA..... well done GT mowog, nice work.
As others have said good to see some actual scientific proof rather than "I know cause i just do... And if you dont believe me im gunna sook" approach that often takes place in some threads.
Well done
Brenton
PostPosted: Mon Mar 07, 2011 11:10 pm
well very interesting. the hardness is only .006" deep, after that it is not much harder than the base material.
So when you look at the test results they obviously put that "folk lore comment" about mini cranks to rest.
Now with this info all I can say is exactly what the heat treaters I deal with have said the same thing. You will not get the hardness any deeper than .006" and that will only be on the machines surfaces. If you "case harden" the crank all over and if you could achieve a greater depth then it would be as brittle as glass.
You can slightly change the "tuffness" of the parent material [if it is the correct alloy] by heating and quenching but there is a risk of again making the crank more brittle.
The only advantage that you might get by leaving a crank in a salt bath for days at 800deg C is than it will stress relieve it to a certain level. Not much more, as the surface hardness will be achieved in a matter of hours.
PostPosted: Mon Mar 07, 2011 11:24 pm
So all in all - any tufftriding/nitriding to a crankshaft is wasted money?
PostPosted: Tue Mar 08, 2011 3:52 am
Mods rock!
I think you want to have a good look at the application and then put that in to the context of funds. It is only intened to be an improved surface hardness of the bearing journals (in the case of a crankshaft). So in the case of the Cooper S, it allowed the engine to usually be rebuilt 2 or 3 times without the need for a crank grind. That is all. It will not increase it's fatigue life.
After some lengthy discussion with another knowledgable member here, as a by-product or side benifit of treatment, because it is done at an elevated temperature and for 15 to 48 hours +, what it can do (NOT always) is stress relieve / normalise the cranks and it IS this which may increase the cranks life. You can certainly do this WITHOUT Nitriding.
Nitriding is good, but it will only do what it is intended to do! It is not a 'miracle saviour'.
Generally, I don't get cranks nitrided or tuftrided (as is applicable to the material) because 60% of the time they come back bent. Grinding them back, IMO, is the incorrect way of correcting them, as the nose and in particular, the tail end up off centre. Mind you this would work if you got a blank (ie a crank straight from being forged / cast) ground it back to about 0.150" oversize, then have it normalised, then finish the grinding process.
PostPosted: Tue Mar 08, 2011 10:26 am
Good work!
It appears that the surface treatment could reduce fatigue cracking at the journal radii by leaving a residual surface compressive stress but rolling these radii is maybe a better way of getting this outcome.
Now, can you do tests of:
(1) Venturis after supercharges as a way of removing charge heat.
(2) Pre-loading of helical coil springs as a way of making them have a variable rate.
:lol:
PostPosted: Tue Mar 08, 2011 6:57 pm
Thanks GT, the price of 'S' cranks has just dropped....maybe I can now afford one! :)
Users browsing this forum: No registered users and 114 guests
