It is currently Sat Jun 28, 2025 2:17 am
Post new topic Reply to topic  [ 221 posts ]  Go to page Previous  1 ... 10, 11, 12, 13, 14, 15  Next
PostPosted: Tue Mar 08, 2011 8:20 pm
dam good thread this one hey??? ;-)
& goes to show (in a sense) why my dad has been sooo right with his method/procedure of grinding down to "slightly" above our intended size, & then balancing & then hardening, then just a thin grind to true both size & straightness of the cranks
the weekend hardening process (as i`ve always said) has seemed to not only thicken the hardening (for want of a better description) but also bend cranks more than just a day process does... but i truely have always believed that it was a stress relieving type of result, & hence why we skim them true after wards & not just linish to size like most do
this is all really food info but i am going to say this---> i`m firmly believing that the hardening process from "heat treatment company" up here in Brisbane may very well have had a better process than the factory one,,, goin on those results from that spridget crank
& i must admit, i have forgotten to have words with my dad about all this (((as i said i would))),,, so i`ll do it before weeks end & get his take on what was & did happen (back in the day)
welll done GT & others,,, damn good thread & i`m sure the "World" mini forum scene will be watching & taking notice of this thread,,, very very interesting indeed
cheers guys
PostPosted: Tue Mar 08, 2011 9:18 pm
willy wrote:
So all in all - any tufftriding/nitriding to a crankshaft is wasted money?
willy, in no way is it a waste of time.
The reason for hardening any mechanical part is to increase wear resistance.... resistance to abrasion... resistance to scratching.... However you'd like to say it, it makes the journel last longer between grinds.
Even 0.005" is beneficial. It will help.
I should have done this in my first post, in this thread,,,, just so we're all on the same page... those of us with qualifications have been using terminology that we understand, but is often missused or miss understood by everyone else... Anyone who either knows me or has read many of my posts knows that I don't believe in with holding info.,., this stuff isn't some "big scary secret" ... or a "dark art"... (bloody hell I learnt it at TAFE doing my trade.... I was just awake in class .... No offence Matt :P )
When we're talking about Mechanical Properties of steel (or anything for that matter), we're basically talking about their make up, their characteristics, and their suitability for different applications.
HARDNESS refers to resistance to denting, scratching and abrasion. Hard materials are brittle... this means that they don't cope well with impact or shock.. as hardness goes up, embrittlment almost parodies it..
THOUGHNESS refers to how well a material resists shock, bending and twisting. If you belt a lump of hardwood with a hammer, you'll put a dent in it, but its not going to shatter,, if you belt ya mums porcelain dinner plate with a hammer it will shatter.... the hardwood is tougher than the plate... and the plate is harder than the hardwood (its not going to scratch or dent) but it won't deal with shock the same way hardwood would.. wood... could a wood chuck.... ok I'll stop :)
ELASTICITY refers to a materials memory.... a highly elastic material will return to its original shape after its bent, twisted or struck
TENSILE STRENGTH is pulling stress.... how hard you can pull on something before it rips in two.
SHEAR STRENGTH is resistance to sideways, or a stress bought about by a sliding action between to parts .... think of a set of shears or tin snips... they shear materal..... a material with "high shear stregth" will be harder to shear.... things like dowels are subject to shear stress.
MALLEABILITY is directly related to plasticity... The correct definition is "The plastic respons to compressive force"... Malleable materails are soft. Think Plasticine,,, its extremely malleable... Lead and Gold are highly malleable as far as metals go.
COMPRESSIVE STRENGTH Is resistance to crushing stress... Materials with high compressive strength can with stand compression and crushing without changing shape. Cast Iron has good compressive strength,, concrete has good compressive strength.... Hard materials will have better compressive strength,, but,, they are more brittle.
DUCTILITY relates to tensile stregth.... to a how a material copes with pulling... ductile materials change shape when pulled
Now, when we are talking about mech properties of steel.... it gets a little more interesting.... or becomes so boring that everyone starts falling asleep :lol:
Metal isn't just metal... see... as you no doubt already know or have already worked out if you didn't know, there are many different types of steel with different elements in them. Steel always has at least Carbon and Iron in it. Steels that are only Iron and Carbon are called "Plain carbon steel".... mild steel is a plain carbon steel....
Now all that stuff I just wrote about "Mechanical Properities" comes into play....
With plain carbon steel, it has limited Mech Properties... its usually tough-ish (remember,,,, tough = resistance to twists, bends and shocks) but not a lot else.... Plain carbon steels with higher amounts of carbon in them are harder... with any steel, the more carbon in it "generally" the harder it is, or the harder you can make it. Mild Steel (MS) only has about 0.15-0.2% carbon. If you want to case harden it, you can't just "throw it over a flame and quench it"... you need "Pack Harden" (basically pack it in a steel box with charcol and barium carbonate,,, or normal salt will work too... thats the "old school blacksmith method" these days box hardening is done differently)....
Now..,.,.,.,.,. Alloy steels.....
First off.... Alloy DOES NOT MEAN ALUMINIUM, but if you weren't from a steel working trade you probably wouldn't know that so we'll forgive you :) ... Alloy means a mixture... so when we "alloy a steel" we mix other elements in with it. Why? To change its make up and provide a more desireable steel for what ever application....
I mentioned earlier that putting more carbon in a steel makes it easier to harden???? Thats great,,,, but what do we know about hard materials??? They're brittle,, they don't like shock, twisting or bending.... so... what if we need a Hard material, that is shock resistant???? We alloy it with elements like Nickel, Chrome, Vanadium and Silicon etc.... What these elements allow you to do, is harden the material, without it becoming brittle.... now obviously, each one of these elements also introduce other mechanical properties to the steel as well... so you need to think about whats getting used where and how much of it.... I won't go into what elements do what... well, not unless you really want me too, but I doubt anyones even read this far! :lol:
What happens when we harden a steel.....
It gets hard.
Ask a vague question get a vague answer.
There are sooooooooooooooot many different types of hardening... what method you use depends on the steel you have, how hard you want it, and how deep you want it (depth of penetration). I won't go list an explain all the different types, because again, I doubt anyone has read this far :lol:
BUT to be reeeeeaaaaaallly general, you could say that there are two groups of hardening.... Case Hardening and Through Hardening....
Case Hardening is where a hard skin is developed. The depth of penetration depends on the material used, and the method of hardening (and then the finer details in the hardening opperation). Most hardened parts you encounter are case hardened. Its by far the common type of hardening.
The appeal of case hardening is that its only the skin that gets hard... the core remains tough.... so you get a wear resistant material thats still tough..... the best of both worlds,,,, its not going to scratch, and it will cope with twisting, bending and impact... BUT, the deeper the case, the more you start trading off your Toughness.. So if its too deep it can still crack.
The other appeal is that its far quicker and cheaper than through hardening.
Through Hardening.... alright... someone else like David might know of some more applications for Through Hardening,, but about the only place I have encounted through hardening is in my trade... With steel, when it gets hot, it grows or changes shape... when you machine it, it relieves and changes shape......... some steels are more affected by heat changes more than others.... By through hardening a suitable steel, you make it diamentionally stable. We use it on Plastic Injection Dies because they go from being hot enough to melt plastic, to cold enough to re-solidify it very quickly, and they need to remain stable to within a 0.01-0.02mm (0.000397-0.001") tolerance.
These Dies aren't subject to twisting or bending. So you don't need to worry about the fact that they are 65+ HRc the whole way through. But they do crack sometimes if they are dropped (and yeah,,,,, I "might" have seen that once..... I swear it wasn't me :shock: )
The only only other time you find through hardening that I know of, is measuring instruments (and again, its for size stability)... and things like files.
Alright..... so knowing that little bit about metals and mechanical properties..... lets have a look at a crank shaft for a second....
What do we know about cranks????
They have journels for bearings..... which are subject to friction which can lead to scratching, scoring and abrasion.... (yeah yeah,,, I know they "float on oil".... but what about start up?? No oil pressure then.... what about cornering so hard that your oil pick up goes dry?? No oil then.... what about when the motor is newly rebuilt and even after you've cleaned the hell out of it there are still microscopic swarf particals floating around your oil ways??? It will cause friction then.... What about when you change gears and wear a little off your synco hub which then goes into the oil ways????? I think you're getting the idea :) )
.... So they have journels for bearings..... which are subject to friction which can lead to scratching, scoring and abrasion
They are subject to twisting forces (torsion)
They are subject to shock (Like David said, every time a cylinder fires, its like the crank is being hit with a hammer)....
Ok,,,, so..... we have a bearings runing on the surface of the journels,.... and then the core of the crank and the webs which are subject to twisting.....
The only part, that needs to be resistant to wear, is the surface of the journal..... the rest of it needs to be able to deal with twisting and impact/shock......
So we want a :shock: ...... "hard" surface on the journal for wear resistance ...... and a............ :)........... "tough" core to cope with the shock and torsion.
Not a waste of time at all. Its a great thing. Just don't get confused about what it does and why its there :) that 0.022" is plenty. If it was through hardened it wouldn't cope with the torsion and shock, it would crack.
Clear as mud??? :) See, not so scary.... (appart from the spelling mistakes :lol: )
PostPosted: Tue Mar 08, 2011 10:22 pm
Nicely put PK, thanks!
No falling asleep here all the way to the end! :lol:
and another tie in would be MadMatt's comments about allowing more clearance to the main cap thrust washers than the block ones cos the crank is going to flex. Being tough, it can cope with the flexure and still have a decent fatigue life but if it were too hard, fatigue life would be much shorter just as the main cap can break if the crank tries to flex it being brittle. Oh and the comments about small journal cranks being less susceptible to fatigue compared to large journal ones, with more overlap between the mains and big ends, the large journal ones would tend to be stiffer but the A series 3 main bearing design inherently means the crank will flex so the stiffer and more unbalanced the crank, the greater the fatigue stresses and a shorter fatigue life...
Kevin
Hey Matt :)
You mentioned earlier that they were salt bathed yes??
Look, there are loads of variables.... but, "sometimes", with "some steels", you can actually get as much as 0.7-ishmm (0.028-ish ") so chances are, your guys probably did know what they were doing. It's possible that yours were coming back at 0.030-ish". I'd believe it.
PostPosted: Wed Mar 09, 2011 8:42 pm
Mods rock!
There has been mentions of crankshaft 'stiffness' throughout this thread and on that subject line, I think Frank Hallam says it best here;-
That is from a book on engine theory and reconditioning practices. It is a bit dated these days, however, the 3 journal crank that he refers to is in fact a 998 Cooper Crank. So, although it is dated, it is far more relevant, to the A series, than any book published today .
Oh and Frank is the Repco side of the Repco-Brabham Engine.
PostPosted: Wed Mar 09, 2011 9:28 pm
Wheres GR :?:
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Wed Mar 09, 2011 9:36 pm
Mini_Maxx wrote:
Wheres GR :?:
113 North Rocks Rd,
NORTH ROCKS, 2151
NSW, AUSTRALIA
:wink:
You're so square
Baby I don't care
PostPosted: Thu Mar 10, 2011 9:58 am
Mokesta wrote:
Good work!
It appears that the surface treatment could reduce fatigue cracking at the journal radii by leaving a residual surface compressive stress but rolling these radii is maybe a better way of getting this outcome.
Now, can you do tests of:
(1) Venturis after supercharges as a way of removing charge heat.
(2) Pre-loading of helical coil springs as a way of making them have a variable rate.
:lol:
What causes a mini crank to crack between center main and N02 big end and how does a radius at the intersection of the brg surface and the web stop this from happening, as distinct form surface cracking due to thermal stress.
as for the two other points you raised, A constant pitch spring and a variable pitch spring are totally different springs. Pre load has nothing to do with the pitch.
Venturi's , question why does a carby have a venturi in the air flow and what does it do and what as the consequences of this action on the air flow.
www.minisprintgt.com
PostPosted: Thu Mar 10, 2011 10:35 am
Off Topic, but Frank Hallam use to machine my mini engines in Geelong. Not sure if the business still exists as I'm sure he passed away in the 90's. I still remember him, always wearing a grey dust coat.
Member VMCI #19
PostPosted: Thu Mar 10, 2011 7:23 pm
adamstuart wrote:
Mini_Maxx wrote:
Wheres GR :?:
113 North Rocks Rd,
NORTH ROCKS, 2151
NSW, AUSTRALIA
:wink:
Just thought he would have something to say on this :?
PostPosted: Thu Mar 10, 2011 7:29 pm
Mini_Maxx wrote:
adamstuart wrote:
Mini_Maxx wrote:
Wheres GR :?:
113 North Rocks Rd,
NORTH ROCKS, 2151
NSW, AUSTRALIA
:wink:
He is probably grinding cams or doing some other worthwhile work. He is a very busy bloke.
PostPosted: Fri Mar 11, 2011 6:52 am
When Mowog took up the challenge to have the crank tested, I thought he was being courageous,
but apparently not, he just knew what he was talking about.
Congratulations to GT for putting his money where his mouth was.
All in all, it has been a very educational thread.
Phat Kat if you were a TAFE teacher you'd keep me awake....a very nice, succinct lesson. :D
PostPosted: Fri Mar 11, 2011 9:12 am
When you know that you know, then you must know right!
Right? :shock:
Good onya mowog!
mooo, I'm a pig!
PostPosted: Fri Mar 11, 2011 9:24 am
Was he related to Paul Hallam as in Hunwick Hallam motorcycles ?
PostPosted: Fri Mar 11, 2011 9:53 am
Milatsmadmini
Mini_Maxx wrote:
adamstuart wrote:
Mini_Maxx wrote:
Wheres GR :?:
113 North Rocks Rd,
NORTH ROCKS, 2151
NSW, AUSTRALIA
:wink:
Yeh... he builds engines and develops cams and stuff for a living... which he needs... and honestly hates the internet... so... if ya wanna know his thoughts...^^^^^ up there is his number.
Users browsing this forum: Bing [Bot] and 88 guests
