It is currently Sat Aug 09, 2025 1:57 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 218, 219, 220, 221, 222, 223, 224 ... 568  Next
PostPosted: Wed Mar 09, 2011 8:44 pm
micowen wrote:
Yes you can, and I'll even personally deliver it!
Jam it up your arse I will!
Pics or ban :!: :lol: :lol: :lol:
:D Drove my kids to school in BALLISTIC :!: 8)
Mods rock!
micowen wrote:
What do you think I made mine out of?
:lol: :lol: :lol:
GREAT!!!! I look backward for it!
PostPosted: Wed Mar 09, 2011 8:46 pm
Mods rock!
photographic evidence or banishment :!: :lol: :lol: :lol:
Hey, that'll be enough of that.
That costs money! :lol: :lol:
PostPosted: Wed Mar 09, 2011 8:52 pm
Even though I caught you on the side of the road in goulburn with a jack in hand doing a quick repair on ballistic, I still love your car!! :D
Hope the kids loved the trip! :D :D
mooo, I'm a pig!
PostPosted: Thu Mar 10, 2011 10:55 am
Remove the engine from the Deluxe so I could check and possibly replace a suspected faulty diff bearing. Found both diff bearings intact and no broken bits in the oil. :? :?
So while the engine was on the ground I decided to make the effort worth while and cleaned the engine, removed the flywheel and checked the primary gear oil seal, which was OK, replaced the thrust bearing and worn spindle. Suspect my original problem was a dodgy Pot joint so I replaced both and then replaced the engine.
Will complete the assembly tonight and take for a test drive.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Thu Mar 10, 2011 7:04 pm
Marcia Prepped & Ready for Blue Slip Tomorrow
I'm Sure I have not forgotten anything
PostPosted: Thu Mar 10, 2011 7:09 pm
Mods rock!
Good luck with it :D
PostPosted: Thu Mar 10, 2011 7:26 pm
Best of luck gaf
You're so square
Baby I don't care
PostPosted: Thu Mar 10, 2011 8:12 pm
Milatsmadmini
good luck mate, hopefully ill join ya for a ride in a few weeks ;)
PostPosted: Thu Mar 10, 2011 9:17 pm
Cheers Guys 6 Years :wink:
PostPosted: Fri Mar 11, 2011 7:00 pm
No luck on the blue slip as I don't have a front bumper (missing body work) other than the suspension need adjusting everything worked perfect.
Very happy Driving Marcia rather than just around the block
PostPosted: Fri Mar 11, 2011 7:36 pm
Find another more understanding blueslip inspector. As per my MSN message advising 2 others.
The front flange is gone and the body is now smooth, so no `bumper' (embellisher strip is a better description) should be no problem.
We blueslipped my son's last Clubby without one.
:wink:
PostPosted: Fri Mar 11, 2011 10:38 pm
removed rhr wheel for tyre replacement, and while i was gone someone hit the clubby pushing it of the jack and stands. all is ok though, and in the end the clubby now has new rear tyres :)
-Motor mechanic - Proud owner of a '76 Clubman S and a Ford ef xr6 manual :P
PostPosted: Sat Mar 12, 2011 9:34 am
removed the cyc head of the Fang engine to find shinny bores. we will get around to removing the a series lump from the rear of the Fang and performing a bit of open heart surgery. We think it may have a cracked piston or 2 plus lots of broken ring after its run at Wakefeild.
Will post pics of the broken bits when we have the time to play doctors and nurses with it.
It vomited a bit over 3 lt of oil out through the breathers in the last 10 min run last Sunday.
But the good news is now I can use the bigger cam I have set aside for it. MORE POWAH !
PostPosted: Sat Mar 12, 2011 10:34 am
I would have left it alone and just plumbed the catch tank back to the sump. :lol: Or just mount the tank behind the rear wheels so you don't spin on your own oil when the tank overflows. :mrgreen:
The amount it was breathing at idle it certainly looked like it needed rings!
