It is currently Sat Jul 19, 2025 3:52 am
 Post subject: Air Conditioner Units
PostPosted: Thu Mar 10, 2011 10:39 pm
hey,
should have my first mini in a week or so (finally)
It's a 74 leyland with a 1330cc engine.
As a future addition i was thinking air conditioner,
would something like this be an easy fit or would it not work at all? http://cgi.ebay.com.au/UNDER-DASH-AIR-C ... 1113wt_901
Are there any other options?
Cheers for the help
Cory
1975 Leyland Clubman -1320cc
PostPosted: Fri Mar 11, 2011 9:26 am
Hi Cory,
depending where you are, Josh from Mini Imports (Ringwood, Vic) may be able to help you out with a 2nd hand kit out of a Rover Mini. I have no idea on the prices but you would have to think it would be competitive compared to ~$900 for something off ebay that you would have to customise to fit.
A lot of the Jap import Rovers that can't be legally registered end up as half cuts tend to have aircon.
David
2008 Prado GXL
PostPosted: Fri Mar 11, 2011 7:46 pm
Yeah, forget the ebay one, would be a pain in the bum. A Rover setup is definitely the way to go. I've seen them on ebay for $3-600, so not too expensive. My mate gave me the setup from his halfcut for nix :D
Josh is the one to talk to ;)
PostPosted: Sat Mar 12, 2011 11:09 am
Cool thanks, will check it out,
How hard are they to fit? Also would up still be able to super charge if I instal they air con
or is there not enough room?
PostPosted: Sat Mar 12, 2011 11:53 am
This space for rent
The Rover aircon at least occupies the space above the clutch housing, with the compressor I believe below the alternator. Most SC setups place the charger above and behind the engine, so I don't see why you couldn't run both.
PostPosted: Sat Mar 12, 2011 7:31 pm
well that's good news. cheers guys.
PostPosted: Sat Mar 12, 2011 8:18 pm
if it's your first mini, just relax and enjoy it as is for a couple of years - get to know the car and how to fix it's little problems before you start making big plans like blowers and air conditioning
Users browsing this forum: No registered users and 21 guests
