It is currently Sat Jul 19, 2025 5:57 am
PostPosted: Sun Apr 10, 2005 9:18 am
Red goes to the live green wire,
black goes to the earth lug on speedo,
white one- fit a double spade connector and it then goes to the 2 light green/brown wires- fuel and temp gauges. :wink:
I just plugged mine into the respective slots on the existing votlage regulator spot?
Haven't tried it yet for obvious reasons - I thought that would still work?
KB
PostPosted: Sun Apr 10, 2005 11:47 am
KB
Roundnose setup different I think. Uses real wires...not that PCB crap. :lol:
PostPosted: Sun Apr 10, 2005 12:29 pm
well, just to add my 2 (unhelpful) cents worth, when you start lizzie (LS) the temp guage goes right up to the red mark b4 the car has sat down to idle!! :shock: :lol: i havnt fixed it cos i dont drive the bitch, but i reckon get a new temp sender....you never know...and i think taking the radiator out and puttingit back in is such a terrible job...
PostPosted: Sun Apr 10, 2005 1:26 pm
Jim you want undo that big end nut they're bloody tight + have a fat compresed spring washer under them - the easiest way to undo is with an air ratchet. Or holding the alt in a vice, a fat allen key inside the shaft (if its hexagon shaped) and uplying ridiculous ammount of force on the nut with a spanner or something.
PostPosted: Sun Apr 10, 2005 3:13 pm
Or, get another alternator...!
I've got an electric rattle gun at work- if nut still not off by Monday nite, gimme and I'll fix... 8)
PostPosted: Sun Apr 10, 2005 6:37 pm
KB
yes of course :roll:
I just assumed everyone else drove a clubbie too! :oops:
KB
PostPosted: Mon Apr 11, 2005 5:29 pm
Okay I chnaged the Regulator :wink: no troubles at all...
So I started Morris up with my multi Meter on it's temp gauge.
15 Minutes till it got to 158f and half way on the Smith temp gauge. So I took her for a drive and down she went 8) Spoke to wife and it was sitting on half most of the way but with Parra Road what d you expect..So I beleive we are out of trouble now :wink: Thanks Guys.
Funny thing was Sue also got a flat on the way to work...Where the trolly jackl...Yep in the Garage :roll:
so it was it was time for "No Real Mechanic Avalible" to do thier job
Cheers guys till next time
PostPosted: Mon Apr 11, 2005 5:33 pm
Sounds like your 35 year old voltage stabiliser had had enough, like my 35 year old brake light switch just did.
Wonder what Lucas (or Smiths) part will fail next... :? :shock:
PostPosted: Mon Apr 11, 2005 7:03 pm
It all happen around Rego Time :wink:
PostPosted: Mon Apr 11, 2005 7:28 pm
Damn right it does. Last week `twas the stoplight switch, this morning the number plate lamp- the brass bit inside it fell apart. So I got a better s/h one from Mini Suzuki in 7 Hills.
Anyhow, I got Ha-Ha's pink slip today!
Cobra race seat on my DrMini frame.. no problem. :wink:
Only thing he didn't like lots was my plastic 1L oil bottle breather can, said it should be metal- so I'll make a beer can one for next time. 8)
PostPosted: Mon Apr 11, 2005 7:38 pm
You Kidding he did not like the Breather...What brand of beer are you going to use :lol:
PostPosted: Mon Apr 11, 2005 7:48 pm
gafmo wrote:
[You Kidding he did not like the Breather...What brand of beer are you going to use :lol:
Dunno- we might have to try 'em all first, until we find a good one.. (hic) :wink:
PostPosted: Mon Apr 11, 2005 8:28 pm
I like that plan Kev.
Steve
