It is currently Fri Jul 18, 2025 6:04 pm
 Post subject: mini Traveller wood kits
PostPosted: Sun Mar 14, 2010 10:40 am
This is a question for those that have purchased a wood kit
with the way the dollar is i am going to order one
I have been quoted from various companies and just wondering about quality and fit etc
All have been about the same price
Mini Spares
M-Machine
Think these are both made by m-machine
Forwoodies
any one had any experience with them
i know some have got the kits from forwoodies which to me so far sounds good since that is what the specialise in is wood kits for travellers and morriss minors etc
regards
allan
PostPosted: Mon Mar 15, 2010 9:31 pm
Just for info
i got quoted
the following so far
Postage is to Lameroo SA.
Mini spares Kit £498.40. + post £159.29.
Forwoodies Kit £495.00. Post is approximately £120.00
I know two people who have got their kits from forwoodies .
think i might go down that path ?
PostPosted: Fri Mar 11, 2011 10:01 am
Holly thread revival Batman! :D
So how did you go in the end?
2008 Prado GXL
PostPosted: Fri Mar 11, 2011 11:52 am
I ordered the wood kit from forwoodies and got it pretty quickly . Very good to deal with. Have had it in the shed for quite some time now. i have not assembled it but the quality looks good.
PostPosted: Fri Mar 11, 2011 11:58 am
Noob traveller question, how do you fasten the wood panels on?
Is it with these through the panels:
What stops moisture getting trapped between the wood and the panel?
Thanks. Wondering if I make my Van more of a Traveller replica.
2008 Prado GXL
PostPosted: Fri Mar 11, 2011 1:36 pm
There is also a very good wood kit being made in America if you go through th minimania web site on their forum and ask where they will tell you . Those that have ordered it have been very pleased , all cnc engineered and all that very competetive price from memory as well
PostPosted: Fri Mar 11, 2011 1:49 pm
That Minimania was one of the first websites I happened when searching for Traveller stuff and put the thought in my head. Ta.
2008 Prado GXL
PostPosted: Fri Mar 11, 2011 2:19 pm
Not cheap though :?
http://www.minimania.com/web/Item/WOOD/InvDetail.cfm
2008 Prado GXL
PostPosted: Fri Mar 11, 2011 2:54 pm
There's meant to be a bead of mastic (a black rubbery sealant that stays a bit soft) around all the edges of the wood. One of the UK companies (somerford) sells something else, I think its like a thin double sided sticky tape that does the same job. They reckon its better.
1955 BSA C11G
1961 Morris Mini Traveller
1969 Triumph TR6R
1977 Leyland Moke Californian
PostPosted: Fri Mar 11, 2011 3:27 pm
I was talking to the owner of a blue Traveller at Wakefield about this. He bought the Somerford stuff and reckons it was just single sided foam rubber which looked the same as you can buy at Clark Rubber. It stuck to the wood before fitting and it did look neat.
Personally I'd rather use Mastic I think. Messy to apply, but it would be very effective in keeping the water from getting between the wood and metal.
Now, if someone just buys my Corona Coupe, then I can get started on it. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Fri Mar 11, 2011 4:01 pm
There's a massive range of sika products designed for bonding and sealing wood to metal etc. I reckon I'll use one of them, messy but very high quality.
1955 BSA C11G
1969 Triumph TR6R
PostPosted: Sat Mar 12, 2011 1:50 pm
I would also paint several coats of marine polyurathane on the wood before putting it on the car , I put one coat on the outside of my previous woody and it worked really well, however some people don't like the shiney look .
PostPosted: Sat Mar 12, 2011 2:09 pm
Mods rock!
How do you guys get on, with repspect to Quarantine, importing wood?
I am unsure either way, but might pay to check
http://www.daff.gov.au/aqis/travel/ente ... /cant-take
PostPosted: Sat Mar 12, 2011 2:24 pm
I can't see any problem.
PostPosted: Sat Mar 12, 2011 5:42 pm
I never had a problem.
Got through customs fine. They did open it to look but repacked it well and forwarded with no problems.
No duty paid either.
Users browsing this forum: Bing [Bot] and 105 guests
