It is currently Sun Jul 06, 2025 9:56 pm
 Post subject: Brake cylinders rear
PostPosted: Mon Mar 14, 2011 7:59 am
Hey one of mine is leaking I am about 99% sure I have Cooper AP 7.5" discs. Which rear cylinders should I be using. From what I remember when I did this last there are 3/4" 5/8" cylinders. Spoke to someone this morning at Mspares & he mentioned 1/16" cylinders.
Which ones guys?
[/img]
PostPosted: Mon Mar 14, 2011 8:19 am
Give Ash some flowers Nick .
For a disc brake front end you need 5/8" rear cylinders. 3/4" rear cylinders are for cars with drum brake front ends.
1/16" cylinders seem a bit small. I would think you may have misheard the measurement.
PostPosted: Mon Mar 14, 2011 9:47 am
I have some new quality QH brand cylinders here that are 5/8. $15 each.
3271 4616 or 0432 841 247
PostPosted: Mon Mar 14, 2011 10:28 am
There is some usefull information on the Minispares UK website.
Here is a brief cut and paste which may assist?
As a guide to start with, working suggestions I have used with reasonable success can be generally channeled into a few groups -
*Discs with 4-pots and latest built-in servo and 7.5" discs with S-type servo, use GWC1131 -- 0.5625"(14.29mm) .
*8.4" discs with or without servo, use GWC1126 -- 0.500"(12.7mm).
*7.5" discs no servo use GWC1129 -- 0.6875"(17.46mm) .
it's a working start.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 14, 2011 11:27 am
TK im in sydney & karkraft is just down the road but I'll let u know. Thanks
Then I'm after the smaller 5/8" ones allowing more pressure to the Cooper discs I have.
