It is currently Mon Jul 28, 2025 1:32 am
PostPosted: Mon Mar 14, 2011 11:11 pm
What's out there that fits without flares?
PostPosted: Tue Mar 15, 2011 10:19 am
LS offset Contessas will fit, needs some caliper modification but not a big deal.
PostPosted: Tue Mar 15, 2011 2:13 pm
I've seen 10x4.5 out of the UK that will fit without flares
These aren't the exact ones I was thinking of, but should still fit:
http://www.midlandwheels.com/Shop/P-2375-4.5-x-10-JBW-Minilight-Silver--165/70x10-Yokohama-A008.html
Offset is +21 so would sit roughly 15mm further in than a standard superlite
10x5 Superlites will fit without flares if you have enough negative camber... :P
PostPosted: Tue Mar 15, 2011 4:45 pm
Hi Michael.
Get some rosepetals.
PostPosted: Tue Mar 15, 2011 4:52 pm
Supercharged
they'll fit but not with disc brakes on the front, also 165 tyres wont fit at the rear, you have to use 145's or spacers, then with spacers they'll hang out the guards a bit.
PostPosted: Tue Mar 15, 2011 6:15 pm
Yep LS mags with 4mm spacers. or 4.5 Techdel Minilites...or Mspares Rosepetals.
Cheers, Ian
PostPosted: Tue Mar 15, 2011 6:29 pm
Get some 4.5" LS wheels. Some bloke was banging on about how good they are a while back.
PostPosted: Tue Mar 15, 2011 7:24 pm
poeee wrote:
Hi Michael.
They do look very good:
http://forum.minicooper.org/showthread.php?t=11617
PostPosted: Sat Mar 26, 2011 8:40 am
poeee wrote:
Hi Michael.
Yeah, I'm not too keen on the look, really.
This interests me. :)
PostPosted: Sat Mar 26, 2011 8:41 am
As long as the tread pattern is in, it's ok..
Hmm...
http://www.minimania.com/web/item/WHL1000/InvDetail.cfm
I prefer the minilite style.
http://www.minimania.com/web/Item/gb5/invDetail.cfm
http://www.minispares.com/Product.aspx?ty=pb&pid=34309
hmm...
God i hope I don't end up choosing contessas...
PostPosted: Mon Mar 28, 2011 9:11 pm
Hmm...
Just run Bald Tyres, seems a pretty simple solution to me. :shock:
