It is currently Sat Jul 19, 2025 1:14 am
 Post subject: Thermostat Housing
PostPosted: Thu Mar 17, 2011 7:34 pm
Sorry if this is a stupid question, but is there a difference between forward and rear facing thermostat housings or can you just change the way it faces? Cheers.
PostPosted: Thu Mar 17, 2011 7:37 pm
Mods rock!
You mean between early Mini and Late Clubmans / Mokes? Yes, they are different and even the rear facing small bore is different to the rear facing big bore.
PostPosted: Thu Mar 17, 2011 8:21 pm
The 3 studs (or bolts) that secure the thermo housing are not eqi-distant, meaning that whatever housing you have only goes on 1 way.
You can change the rear facing housing to a front facing housing by using the proper housing and the associated radiator, top hose and top rad bracket.
Hope that answers your question.
Steve
