It is currently Fri Jul 18, 2025 10:15 am
 Post subject: New to mini scene
PostPosted: Thu Mar 17, 2011 3:34 pm
Hey guys , just new to mini scene , have a few question to ask about mini . I just purchase a leyland , just wondering what oil is suitable for that model ? And is it normal for the car to blow black smoke ? And has anyone remove or repair there own rust damage ?
PostPosted: Thu Mar 17, 2011 4:04 pm
If it is a standard leyland mini (71-78 ), you just need basic mineral oil as these engines trace their origins back to the 1940s. Even the most basic modern oils are now superior to most of the stuff you could buy when your car was new.
Any of the k-mart or supercheap brand oils are fine, valvoline XLD, castrol GTX - just any basic 20W-50 Mineral oil is fine. If the engine is worn and it is using oil at the rate of more than 1L per 1000-2000km you may need to go to a 25W-60 or thicker oil designed for older engines. Don't use synthetic oil, as the seals in your engine will not be used to it and could end up causing oil to leak out everywhere.
Probably a more important issue is to change the oil regularly, don't leave oil in there for more than 5000km - the engine and gearbox use the same oil (but you probably knew that already :) )
Black smoke means you're probably running rich (i.e. engine is getting too much fuel). Probably needs a good tune up. Also maybe check to see that the choke is fully pushed in when warm, and that your air filter is not dirty. If you've just bought the car, you will probably need to give it (or take it in for) a major service - unless you have receipts and records to show that all the fluids have been changed and it's been servicing recently, assume it hasn't and it's time to do so!
There's heaps of people on here who have repaired rust damage themselves, some with good picutres. Use the 'search' function at the top of the page to search for old topics - most of them will be in the 'mini chat' subforum.
Welcome to the joy that is mini ownership! Be sure to upload some photos of your ride for us to look at and if you go to your profile and fill in your suburb/town location then the members who are local area will be able to do things like suggesting local mechanics and specialists who can help you with your car, give you advice on where to get parts etc.
+ Too many other classics
PostPosted: Fri Mar 18, 2011 7:42 am
hey buddy , thanks for the reply my question has been answer , very helpful , i live in sydney and found a place in padstow , so im checking the car in for a regular check up next week.
before i purchase the car the last owner had it check n service in jan , few parts were replace such as the cv joint , clutch bearing so so ...! just the rust thats bothering me , dont want it spread.
PostPosted: Fri Mar 18, 2011 4:07 pm
Hey mate welcome to the forum.
You can also take it to Mini Classic at Hope Street Ermington - the only place I trust with my car. Padstow is good too.
Many of us swear by Kmart's own KMX 20W40 for $20 for 6L. It's a very very good oil but yes, take advice above about user thicker oil if you're engine is more worn. Since it's only $20, you can afford to change the oil every 2500kms instead of 5000 or whatever. I do mine every 1000.
Go to Mekong Auto Spares on Canley Vale road (near the station and should be 5 mins up the road for you!) and buy oil filters there for around $4.50 each. Get like 10 and you'll be set for years (depending on how often you drive it)
Look out for the next SWOM meet in the events section and join us at Liverpool Harry's De Wheels sometime! love to see your clubby!
Lillee - 1969 Morris Mini K
PostPosted: Fri Mar 18, 2011 5:53 pm
Rust repair, work in progress.
See here: http://www.ausmini.com/forums/viewtopic.php?t=66890
I haven't seen many as bad as mine, that either means I am very clever or very stupid. Probably the later :?
Mini's I grew up with
Slot car couch
PostPosted: Fri Mar 18, 2011 6:04 pm
Yeah Rusty, mate i would of run 10 miles at the site of the rust in your car, ya got bigger balls than me , let me tell you, credit to you for having a crack at it.
PostPosted: Fri Mar 18, 2011 6:50 pm
I reckon Micowens "lil Grunt" would be on par with your rusty one
Master of the Moggie Army & Founder of Awesomestock2010
PostPosted: Fri Mar 18, 2011 8:11 pm
Thanks goodie,
My brother was up at Christmas (my car hasn't progressed much since then) and said, yep your cars about at the stage now when I might consider restoring it :lol:
Actually about 95% their now with the rust work, so looking good from here on in!
Slot car couch
PostPosted: Fri Mar 18, 2011 8:12 pm
Maxx,
I think you might be right! Makes me feel much better, cheers :wink:
Slot car couch
