It is currently Tue Jul 29, 2025 1:27 am
PostPosted: Mon Mar 28, 2011 8:46 am
i Guys, Starting to reassembe the Cooper S Bits and pieces while waiting for the Body Shell to arrive home.
Just need some guidance, I have checked the manuals but they say nothing. I have previosly had the fuel pipe go straight into the fuel bowl thing, then it went via an other pipe to the 2nd carb. Looked a bit crapy, so I ordered the original metal pipe and looks much neater.
Now do I have to block the little copper pipe that used to be connected to the fuel line?
CHeers Brett
PostPosted: Mon Mar 28, 2011 10:49 am
see if you can guess what happens if you don't - it would normally be connected to another carb that would receive full fuel pressure
I'd dig up another float bowl lid that doesn't have the extra pipe - looks neater
