It is currently Sun Jul 27, 2025 10:26 pm
PostPosted: Mon Mar 28, 2011 11:00 am
Of the following.
After finally getting my mini running again after a 2 year hiatus i noticed that when i give it a decent quick rev from idle, the engine feels like its starved near to the point of stalling before it revs up. To stop it doing so i have to give it a little half rev in the middle of the low point to keep it alive. The engine is supercharged with one of 92's SC12 kits and even in my limited mechanical knowledge i figured its a fuelling issue and im leaning towards it not getting enough??? Ive checked the dashpot oil and it seems plenty full which i hope rules that out. Would a different needle help or perhaps richening up the mix?
thanks again
trent
PostPosted: Mon Mar 28, 2011 11:08 am
yeah, it leans out - if you watch the dashpot piston it's probably jumping up when you rev it. Try thicker oil (I put 20/50 engine oil in mine). I'm getting a heavier spring too
get a little torch and look down the carb throat as you rev it, you'll see the fuel spraying out, and how the flow changes when you rev it
PostPosted: Tue Mar 29, 2011 9:32 am
I did as you said and its all fixed, thanks heaps!!!
PostPosted: Tue Mar 29, 2011 9:47 am
yay! I got one right :D
Users browsing this forum: fuzzy-hair-man and 100 guests
