It is currently Sat Jul 26, 2025 11:18 pm
 Post subject: Nylon cap for uni joint
PostPosted: Mon Mar 28, 2011 7:17 pm
I had a problem where one of my unis let go at it destroyed the nylon caps.
They were replaced with rubber unis, but I'm having some clearance issues, even after they were taken to with the grinder.
Basically, I'm trying to source some new nylon caps. Any advice?
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
www.minisinthegong.com.au
PostPosted: Mon Mar 28, 2011 7:20 pm
You can buy the whole QL5000 joint new again, but I don't think the caps/cups are available separately.
PostPosted: Mon Mar 28, 2011 7:27 pm
Thanks Doc,
can you point me in the direction of a store. Had a quick look at minisport SA online store and couldn't see them.
I will do a search.
At the moment, I'm only getting a bit of noise at high speed (eg 80kmh +). At first I thought it was wheel bearings. But pulled them apart this arvo and it looks fine, no play etc. this sound only started after putting the rubber unis in.
I have enough caps for one side.
If i were to put the nylon style back in to test if this is indeed my problem, would there be an issue with having rubber one side, nylon the other (just to test, not permanently.)
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Mar 28, 2011 7:30 pm
Karcraft stocks them, p/no QL5000. Around $100 PAIR. :wink:
www.karcraft.com.au
Don't overtighten the nuts- 8lb/ft MAX is correct I think.
PostPosted: Mon Mar 28, 2011 7:34 pm
thanks doc.
Do you see a problem with running nylon on one side and rubber on the other side just to see if it definantly fixes the prob. (I don't want to spend $100 for nothing).
Ryan
Ryan Filippi
Minis In The Gong
[email protected]
PostPosted: Mon Mar 28, 2011 7:47 pm
Mods rock!
www.karcraft.com.au
I just check their stock, they presently have none on hand and no 'due date' either. Cricky, these have gone up since I last bought some.
PostPosted: Mon Mar 28, 2011 8:14 pm
www.karcraft.com.au
Minispares seems to have in stock-
http://www.minispares.com/Product.aspx? ... 448&title=
I do have a drawing (not mine) for the nylon cups if you want to get some made-
I won't post them on here though, PM me for a copy. :wink:
ps i also have a drawing for steel cups.
Note the U/J inside these kits is same as a Triumph TR6, can be bought separate.
Last edited by drmini in aust on Mon Mar 28, 2011 8:19 pm, edited 2 times in total.
PostPosted: Mon Mar 28, 2011 8:18 pm
And you would probably have them in about 1 week from minispares :)
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Mon Mar 28, 2011 8:33 pm
There are QL5000s on ebay. some new, some NOS, often they will be less than $100 delivered ;)
When you put the rubber unis in did you make sure the wheel was at about normal ride height (wedge under the top arm)?
If not they will be "tweaked" under uneven pressure, giving you vibration and other issues.
cheers.
Jacob
PostPosted: Tue Mar 29, 2011 7:45 am
Heritage Mg in sydney also carry these nylon joints. $105 a pair plus freight.
Comes with new u bolts and nuts, washers etc..
Im looking to buy some new ones for my own at the minute...
Jack of all trades, master of none......
PostPosted: Tue Mar 29, 2011 7:48 am
Give Ash some flowers Nick .
I just put a set of these in my car. Just check the U bolts before you put them in because 7/8 of mine were too far apart (were more like 170°) so wouldn't fit through the yokes. I had to put the nuts on them and squash them down in the vice to make them fit.
PostPosted: Tue Mar 29, 2011 12:13 pm
from memory it was a local mechanic who knows minis that put the new UJ in so im assuming he would know how to do it properly
PostPosted: Tue Mar 29, 2011 3:33 pm
Wilo is right.
He also mentioned the clearance issues.....unfortunately he has gone away at the moment and I'm sure he would also have the nylon caps in stock (he always seems to have exactly what I need).
Ryan Filippi
Minis In The Gong
[email protected]
