It is currently Tue Jul 29, 2025 6:45 am
PostPosted: Tue Mar 29, 2011 8:30 am
I'm a noob when it comes to building engines, but would I be right in thing that smoke is white, not a bluish colour?
I know you can expect a reasonable amount of smoke with a new engine (with an new parts, really). I changed my exhaust and manifold, and it was smoking like what you have in your pics there for perhaps 10 minutes. Nothing was wrong, it was just the new parts 'smoking' in.
PostPosted: Tue Mar 29, 2011 8:35 am
that's really really wierd :?
I'm no expert either, but I don't expect a new engine to smoke. I usually have a bit of oil on top of the pistons on first startup, but it burns off in a couple of revs, then nothing
PostPosted: Tue Mar 29, 2011 8:36 am
a new engine, (one that has been built well & nothing wrong with it internally) should start up with a slight puff of smoke (assembly oil) & clear almost immediately (within seconds)
if it continues to smoke for a long period of time then i`d suggest that either:::
the oil expander rings have been overlapped when fitted
or the ignition advance is "WAY" to much
or oil is being sucked in via poor breather catchers
or there is a pile of old oil still residing inside the exhaust pipe
or there are a few more silly reasons, but generally & most commonly (from what i`ve seen of "other" peoples mistakes in the past) the oil rings have been fitted overlapped
i`m not saying that this is "Your" problem ,,, so check your ignition advance first & then your breathers, but if it keeps smoking then i`d be stripping it down & checking the rings
PostPosted: Tue Mar 29, 2011 9:25 am
Unfortunately, this is the one I suspect. . .
I know some of the history of this engine and it's setup (in fact that's me standing in the smoke haze. . . :) ).
Timing is pretty much spot on - 10 degrees.
There are no breathers on this motor (something that will need to be rectified) but it continues to smoke even when running with the oil cap off.
There isn't any old oil in the exhaust - the old motor was tired but not a 'smoker'. . .and the smoke continued for way too long in any case.
After running for a while, there is a lot of visible oil on the piston crowns. . .more that I would ever expect to be able to be continuously fed down the inlet guides.
Sadly, I think it all has to come out again. . .
PostPosted: Tue Mar 29, 2011 9:54 am
That much smoke can only mean rings or bore related issue. Even running old guides with no oil seals will only smoke up for the first 5-10 seconds and not as much as in that photo! :shock:
PostPosted: Tue Mar 29, 2011 10:47 pm
Thanks for all your help guys :D
PostPosted: Wed Mar 30, 2011 9:35 pm
That's no good after all that work! Hope it hasn't caused any damage to the bores.
68 Mini
70 Moke
PostPosted: Wed Mar 30, 2011 10:01 pm
You and me both
PostPosted: Wed Mar 30, 2011 10:15 pm
Nah it shouldn`t , "IF: it`s the oil rings over-lapped causing the smoke, then "Butt" them correctly & whack it all back together again & she`ll be all hunky-Dory
PostPosted: Thu Mar 31, 2011 9:35 am
In the photo withthe car running I cant see if you have fitted the brakes yet. Is there is a booster fitted and bled??? If it is faulty the bell can fill up with fluid. Vacuum sucks it into the intake and burns white.
1962 Mini Speed sports sedan
PostPosted: Thu Mar 31, 2011 11:35 am
Nope - no booster on this one. . .definitely oil smoke, not brake fluid smoke. . .
