It is currently Sun Jul 27, 2025 3:48 pm
PostPosted: Tue Mar 29, 2011 10:40 am
Have noticed lately that my gear change in the 3rd - 4th plane seems to be getting tighter.
Is there any grease points like there is on the remote boxes? If not what is the usual problem(s) with the rod change mechanism to look out for?
Jim 8)
PostPosted: Tue Mar 29, 2011 10:57 am
What sort of condition is the two roll pins and the rubber cotton reels holding the stick housing in like? If any are worn bad enough there could be a misallignment issue causing that.
PostPosted: Tue Mar 29, 2011 11:01 am
I was under the car recently, all the cotton reels are fine... the roll pins I don't know. The car is due a grease very soon, I'll have a look then.
Is there anything that has to be greased on a rod change? :?:
PostPosted: Tue Mar 29, 2011 11:06 am
only in the gearstick thingo...
but it's selecting OK, just stiff?
PostPosted: Tue Mar 29, 2011 11:10 am
It selects fine, just feels tight especially when going into 3rd gear. 1st and 2nd seem fine. :?
PostPosted: Tue Mar 29, 2011 11:32 am
Mods rock!
Is the any (even the tinest amount) of back and forth play when is 3rd or 4th?
PostPosted: Tue Mar 29, 2011 11:41 am
About 1/2" - 3/4" in 3rd, about 1" in 4th. Also my car was originally a remote change, but NMP converted it to rod when the A+ gearbox and motor went in. Not sure if this is relevant or not.
PostPosted: Tue Mar 29, 2011 11:52 am
Mods rock!
Could be a worn selector hub, worn selector fork and / or work spigot bearing (between 1st & 3rd mostion shafts), this is by no means certain, but that you have some play and all other gears selecting OK, tends to indicate that the shifter side of it is working alright.
PostPosted: Tue Mar 29, 2011 12:16 pm
Thanks all for your help. I'll have a closer look underneath at the rod side of things soon. If it is the selector side of things in the gearbox, it will have to wait... for a while... a long while. 8)
Users browsing this forum: mincs1 and 90 guests
