It is currently Mon Jul 21, 2025 8:07 pm
PostPosted: Fri Apr 01, 2011 5:04 pm
The floor pan I have, which was from an Ausi Clubman is bulkier around the gear change, and higher in front of the gear change, than the standard roundnose floor pan.
PostPosted: Fri Apr 01, 2011 5:25 pm
Harley wrote:
The basic `Oz hydro channel' floorpan was unchanged from 1967 to 1978, except there were 2 patches bumped upwards in a die, where the cottonreel mounts are.
I'd be lighting the oxy up and using a VBFH from underneath to duplicate said bumps. :wink:
But then you'd want to weld in the higher transmission tunnel, wouldn't stretch that.
:D
Are you SURE it's higher, it looks the same to me.
UK cars got a taller, squarer tunnel, but Oz never did.
Hint: the crossmember is the same on all ours, so how can the tunnel be higher..??
I mean it is more bulbous, around an inch higher for a 6 inch radius around the stick.
(photos nicked from mini_finatics 850 build thread)
PostPosted: Fri Apr 01, 2011 6:03 pm
OK I see what you mean now. It's been a while since I had a Clubby.
I've converted more rodchange cars to take a proper remote.. no problem once you drill 3 holes.8)
PostPosted: Fri Apr 01, 2011 7:40 pm
I did this recently. Faffed making my own brackets but in the end just ordered the kit from Minimania in the USA. Fitted it two weeks ago. Easy job.
Users browsing this forum: No registered users and 72 guests
