simon k wrote:
The electric fuel pump won't stop fuel flowing through it, and if gravity empties the fuel bowls into the manifold, the needle & seats won't stop the bowls refilling
simon k wrote:
Bubbacluby wrote:
hopefully the filter will catch anything before it jams the needle and seat open again.
that's not the cause, the needle and seat (both of them for you) - re-read what I said above.
If the tanks are full, and the fuel is above the level of the carbs, the system will just syphon it through
Im not sure if im following you.
It doesnt matter if the fuel bowls are full or not, the electric pump will pump until it has reached pressure and then stop (ie the fuel bowl filled and needle and seat stopped fuel flow).
So what your saying is the pressure of the fuel in the tank being higher than the presure in the fuel bown that pushes the needle and seat upwards so it will be unable to seal and keep flowing in? Thats doesnt sound quite right to me
Our driveway isnt massively steep, its a little steep and not steep enough for the above to happen anyway
I had some gunk (I assume from my tanks) get stuck on the seat in the fuel bowl lid. So when the fuel bowl became full and caused the float to rise pushing the needle up to form a seal, it was unable to because of the rubbish stuck, hence because there was no seal the power of gravity caused the fuel to keep running - down my carby, into head, down bore and into sump
Brenton
